What package provides “remove-unused-packages”?
# rpm -q --whatprovides remove-unused-packages
returns nothing.
Hi @ben79
# which remove-unused-packages
/usr/sbin/remove-unused-packages
# rpm -qf /usr/sbin/remove-unused-packages
drakxtools-curses-14.56.12-1.1-omv2014.0.x86_64
Thanks luca.
Then '‘remove-unused-packages’ and drakxtools-curses are broken in Lx3 and probably Cooker as well.
This is what I get:
# remove-unused-packages
Too late to run INIT block at /usr/lib/perl5/vendor_perl/5.20.3/x86_64-linux-thread-multi/Glib/Object/Introspection.pm line 257.
Subroutine Gtk3::main redefined at /usr/lib/perl5/vendor_perl/5.20.3/Gtk3.pm line 525.
/usr/bin/perl: relocation error: /usr/lib64/libldetect.so.0.13: symbol pci_init, version LIBPCI_3.0 not defined in file libpci.so.3 with link time reference
luca: Yes I get same. It is the last line that shows the problem, first 2 lines are there when it is working.
This looks like the culprit:
will you tell something to tpg?
Filed bug report:
https://issues.openmandriva.org/show_bug.cgi?id=1711
don’t have direct communication with TPG. Do you?
no, only quarrels, I was just kidding
devs hate bugreports
Please fix bugreport number, 1711 seems to be the right one.
Woops! Fixed. My Freudian slip was showing…
See thread “Thunderbird won’t install”.
