Welcome Screen Button issue : Calligra
Hello again, i am currently trying all the welcome screen option to see which one are failing or not. In the welcome screen —> Application —> Office —> Calligra, it do download all the package, and throw an error of failure. Using DNF throw zero error and proceed to install the 56 packages downloaded properly.
dnf_python_crash_at_16h22.txt (954.1 KB)
It seem the error’s due to some python crash at 16h22 in the log, where at 16h24, i did try again and it worked fine over dnf on terminal.
Thanks for reporting.
The real problem looks to be this:
install of bluedevil-5.27.12-1.x86_64 conflicts with file from package plasma6-bluedevil-6.3.4-2.x86_64
Does not install from OM-Welcome. I got a different but similar error:
install of okular-common-23.08.5-2.x86_64 conflicts with file from package plasma6-okular-common-25.04.0-1.x86_64
Both errors are the script wanting to install old Plasma5 package which conflict with installed. Plasma6 package.
Possibly something in the script used by OM-Welcome needs to be changed?
I can confirm that the package installs from cli.
This appears to be a problem related to OM keeping Plasma5 while also using Plasma6. Since Plasma5 is finally being removed in Cooker this stuff will get fixed eventually but it may take some time. A lot of this should be fixed by the next big upgrade for ROME which will remove the Plasma5 stuff. I am hoping for that to happen very soon. :crossed_fingers:
And I should suggest to @HerbalNekoTea that it may be a good idea to file a package update request here.
