This seems to resolve my errors. Thank you very much. I will mark it as resolved. To anyone coming here for help, keep in mind there are two solutions here: the one marked, and the suspend services activation, each of which is a command in the form:
sudo systemctl enable nvidia-suspend, etc.
As I go, is there any thoughts on whether I should re-attempt to use the open modules?
OpenMandriva Rolling - x86_64 7.0 kB/s | 2.4 kB 00:00
OpenMandriva Rolling - Non-free - x86_64 7.4 kB/s | 2.4 kB 00:00
Error:
Problem: problem with installed package kernel-rc-desktop-6.15.0-0.rc2.3.x86_64
- package nvidia-575.51.02-1.x86_64 from rolling-x86_64-non-free requires ((nvidia-kmod-rc-desktop or nvidia-kmod-open-rc-desktop) if kernel-rc-desktop), but none of the providers can be installed
- conflicting requests
Your advice fixed also my issue with suspend OM X11 with nvidia gpu. Thank You - maybe this info should be added somewhere - welcome app installing nvidia drivers section? I think it would be helpful.
Thanks.
It would be great if you can make a clear summary point by point of the steps to get it done, for the posterity.
That could also find its place in Resources category
