ROME 25.06 latest packages updates, x11
KDE
om-welcome opens, show window with white background then crash
$ om-welcome
Detected locale "C" with character encoding "ANSI_X3.4-1968", which is not UTF-8.
Qt depends on a UTF-8 locale, and has switched to "C.UTF-8" instead.
If this causes problems, reconfigure your locale. See the locale(1) manual
for more information.
QTWEBENGINE_FORCE_USE_GBM environment variable is set and it is for debugging purposes only.
GBM support is force disabled.
GBM is not supported with the current configuration. Fallback to Vulkan rendering in Chromium.
Qt depends on a UTF-8 locale, and has switchedDetected locale "C" with character encoding "ANSI_X3.4-1968", which is not UTF-8.
om-welcome.txt (32.1 KB)
Ryzen 5800x, rtx3070
