- OpenMandriva Lx version:
Rolling
Plasma
Unusual problem with LO in Rolling. System is fresh install and LO has not been used. When I first open LO Writer I see this:
If I select to Discard then LO seems to work normally. But if I select Save all LO apps become unresponsive. The only remedy is to re-install all the LO packages and next time select Discard. Additionally when I had selected Save and then try to run any LO app in cli there is nothing, no output. Also nothing in journal logs.
I suspect this will be fixed when devs next copy Cooker stuff to Rolling. We are hopeing for this to happen soon.
