ROME -
Plasma5, Plasma6, or LXQt (This probably pertains to ALL) -
This is a result of the name change of theunsupportedrepository toextra. This is an instance when users want to select Y to accept the new .repo file. Other wise there will be dnf errors saying it can not access theunsupportedrepo. (Assuming user hasunsupportedenabled).
An alternative solution would be to edit the .repo file in use and change every instance of unsupported to extra. This can be easily done with Kate or Kwrite editors. To do this go to Edit>Replace then in the ‘Find’ line type unsupported and in the ‘Replace’ line type extra and select ‘Replace All’. I have not tested this but it should work.
Another alternative is to edit this section of the .repo file:
There are 3 lines that will have the word unsupported you need to change all of those to extra. You can do this with whatever editor you choose.
Note: The .repo file in use for ROME x86_64 is /etc/yum.repos.d/openmandriva-rolling-x86_64.repo. For ROME znver1 /etc/yum.repos.d/openmandriva-rolling-znver1.repo. If you are using aarch64 probably it is /etc/yum.repos.d/openmandriva-rolling-aarch64.repo.
