VMware Player 12.5.7
I tried to install VMware Player 12.5.7
Downloaded from Dell website. https://my.vmware.com/en/web/vmware/free#desktop_end_user_computing/vmware_workstation_player/12_0
[root@localhost Downloads]# ./VMware-Player-12.5.7-5813279.x86_64.bundle
Extracting VMware Installer…done.
/usr/share/themes/Breeze/gtk-2.0/widgets/entry:70: error: unexpected identifier direction', expected character }’
/usr/share/themes/Breeze/gtk-2.0/widgets/styles:36: error: invalid string constant “combobox_entry”, expected valid string constant
VMware Player crash.
I told this in 3.02b too.
But it was not fixed.
How to fix it?
There is a Fail Service too.
I need this fixed. Thanks…
https://communities.vmware.com/thread/568662
I apologize I’m not an expert of vmware but just installing the package vmware-view-open-client is not enough?
I haven’t used vmware-view-open-client.
As I understand vmware-view-open-client is a remote desktop client.
https://my.vmware.com/web/vmware/info?slug=desktop_end_user_computing/vmware_horizon_clients/1_0
VMware Player is a virtualization software like Oracle VirtualBox and Windows Virtual PC. And it is widely used.
https://www.vmware.com/support/ws5/doc/learning.html
I installed VMware® Workstation 12 Player on openSUSE leap 42.1. Yesterday VMware Representative gave me a call but I do not have Paid support. :(. I will try to sort this out.
First I admit to not knowing very much about VMWare.
For what it’s worth a lot, most, maybe nearly all OpenMandriva testers are using VirtualBox. That’s partly because there is a free and sort of open version. And partly for standardization regarding test results and problem solving. At one time it was deemed easier to have one ‘brand’ of VM instead of several.
Don’t know if this might be something you would want to try?
I installed Oracle VirtualBox but It is like locking to a one software.
I can work on VMware Player, VirtualBox, Windows Virtual PC, etc
As I know VMware is in the forefront of virtualization.
Check this too…
Had a discussion with VMware / Dell Representative. Hope this will increase your knowledge for supporting future VMware products ;-).
"As per our discussion, you may refer our online support as below:
Please note that we also provide online support for our products. You may visit the websites below to review:
Knowledge Base Articles:
http://kb.vmware.com/selfservice/microsites/microsite.do
Documentation:
https://www.vmware.com/support/pubs/
Technical Papers:
http://www.vmware.com/resources/techresources/
Community Forum:
http://communities.vmware.com/index.jspa "
" You may also contact Technical Support Team directly by phone.
Please call and choose option 4 for “Technical Support” when prompted. You can find a local contact phone number here:
http://www.vmware.com/support/phone_support.html
If you do not have an active support on your product currently, then you need to purchase Per Incident Support(One Time Support) from the Store.
To purchase and file Pay Per Incident support for VMware products please refer the link below:
http://kb.vmware.com/kb/2014035
Purchase link below:
If you are a VMware Partner, please refer to the KB article below. It provides instructions on how to login to Partner Central, retrieve your support code; activate your support code and log on to your My VMware profile to create a technical support request.
http://kb.vmware.com/kb/2011781 - “Filing a Support Request using a Partner Support Code”.
[http://download3.vmware.com/socialmedia/icons/social-icons-vm.png]http://kb.vmware.com/selfservice/microsites/microsite.do
VMware KB - Knowledge Base Articles for all VMware Productshttp://kb.vmware.com/selfservice/microsites/microsite.do
kb.vmware.com
VMware KB Article Title: Type of Document: Last Modified: System requirements to install a 64-bit guest operating system on a 32-bit host (1003945)
kb.vmware.com
kb.vmware.com
Documentation:
VMware Documentationhttps://www.vmware.com/support/pubs/
VMware is the global leader in virtualization software, providing desktop and server virtualization products for virtual infrastructure solutions.
www.vmware.comhttp://www.vmware.com
Technical Papers:
Community Forum:
Looking forward to your response."
Tried to install VMware Workstation Technology Preview 2017 for Linux (VMware-Workstation-Full-e.x.p-6056110.x86_64.bundle)
While installing I got this error.
[root@pujitha-pc Downloads]# chmod 777 VMware-Workstation-Full-e.x.p-6056110.x86_64.bundle
[root@pujitha-pc Downloads]# ./VMware-Workstation-Full-e.x.p-6056110.x86_64.bundle
Then, This. I need these Kernel Headers. They are not available in mcc
It’s just an error of the graphical theme, maybe you may ignore it
Maybe it can be linked to this bug.
Edit:
There is a discussion too.
I’ll bet you do have kernel-release-headers-4.11.3-2-omv2015.0.x86_64 in mcc. That’s what the kernel headers package is called.
If you have that installed you may need to do what the error message is telling you and specify the path manually. This is normal when one is dealing with 3rd party software.
Error in installation. Another issue I face is: If I open multiple tabs in Chrome and then open MCC PC gets stuck. Better look, at this too.
May I know the “kernel-release-headers” path too.
1 installation transactions failed
There was a problem during the installation:
file /usr/include/asm-generic/..install.cmd from install of kernel-release-headers-4.11.3-2.x86_64 conflicts with file from package kernel-headers-4.1.18-1.x86_64
file /usr/include/asm/..install.cmd from install of kernel-release-headers-4.11.3-2.x86_64 conflicts with file from package kernel-headers-4.1.18-1.x86_64
file /usr/include/drm/..install.cmd from install of kernel-release-headers-4.11.3-2.x86_64 conflicts with file from package kernel-headers-4.1.18-1.x86_64
file /usr/include/linux/..install.cmd from install of kernel-release-headers-4.11.3-2.x86_64 conflicts with file from package kernel-headers-4.1.18-1.x86_64
file /usr/include/linux/android/..install.cmd from install of kernel-release-headers-4.11.3-2.x86_64 conflicts with file from package kernel-headers-4.1.18-1.x86_64
file /usr/include/linux/byteorder/..install.cmd from install of kernel-release-headers-4.11.3-2.x86_64 conflicts with file from package kernel-headers-4.1.18-1.x86_64
file /usr/include/linux/caif/..install.cmd from install of kernel-release-headers-4.11.3-2.x86_64 conflicts with file from package kernel-headers-4.1.18-1.x86_64
file /usr/include/linux/can/..install.cmd from install of kernel-release-headers-4.11.3-2.x86_64 conflicts with file from package kernel-headers-4.1.18-1.x86_64
file /usr/include/linux/dvb/..install.cmd from install of kernel-release-headers-4.11.3-2.x86_64 conflicts with file from package kernel-headers-4.1.18-1.x86_64
file /usr/include/xen/gntalloc.h from install of kernel-release-headers-4.11.3-2.x86_64 conflicts with file from package kernel-headers-4.1.18-1.x86_64
file /usr/include/xen/gntdev.h from install of kernel-release-headers-4.11.3-2.x86_64 conflicts with file from package kernel-headers-4.1.18-1.x86_64
file /usr/include/xen/privcmd.h from install of kernel-release-headers-4.11.3-2.x86_64 conflicts with file from package kernel-headers-4.1.18-1.x86_64
In mcc for vmware-view-open-client I get this.
Sorry, the following packages cannot be selected:
  • vmware-view-open-client-4.5.0-2-omv2013.0.x86_64 (due to unsatisfied libboost_signals.so.1.53.0()(64bit))
