This is not relevant to Oracle versions of VirtualBox, it applies only to OM versions. I do not know if the latest Oracle version does or does not work in ROME or Cooker.
I have Cooker, ROME, and Rock/6.0 partitions
I use KDE Plasma6 desktop currently
Newer versions of VirtualBox in ROME and Cooker no longer work. This will occur in Rock when the next Rock release occurs. (VirtualBox versions newer than 7.1.8)
As far as I know the latest OM version of VBox that will work is 7.1.8 which needs kernel 6.14.x. If you use or want to use OM’s VBox I would advise downloading the versions of VBox and kernel for your arch from OM Rock/6.0 repos. It would be useful to have these in case either VBox or the kernel that works were to be removed during a dnf dsync upgrade.
If someone has a newer OM version of VBox working please post here how you have done that so I can try what you have done.
The word from devs is that newer OM versions of VBox will not work until sometime in the future when VBox devs switch to kvm for virtualization. I have no time frame for when that will be.
I really, really, do not like recommending for users to use an older kernel. What I do in ROME is I have kernel 6.14.2-3 installed along with the latest available for ROME and only boot in to 6.14.2-3 when I need to use VBox. For Rock these versions are what are in use for Rock/6.0 so Rock users will not see this problem until the next version of Rock is released.
For upgrading without upgrading VBox use sudo dnf dsync --refresh -x virtualbox. As far as the kernel upgrades OM by default keeps the 3 latest installed kernel versions. So I remove one of those before doing a dnf dsync so the new kernel can install without removing the 6.14.2-3 version.
I hope this is useful. If I have not explained anything well enough just ask and I’ll try to explain better.
Edit: If you use VBox download these packages for your system now. When the next Rock release occurs they will no longer be in Rock repos and they are not in ABF anymore. Yes I expect this to be resolved someday. Whether someday is 2 days, 2 months, or 2 years or more is unknown.
