The big one is that kernel modules do not load on boot. I have to modprobe them every time I reboot. I tried adding them to /etc/modprobe.preload.d/modprobe-preload.conf and that did not work. Then as you see I tried installing dkms-virtualbox. Well that won’t work currently because:
Preinstalling packages needed for building kernel modules. Please wait...
Installing : dkms-2.6.1-5.noarch 2/3
Running scriptlet: dkms-2.6.1-5.noarch 2/3
Failed to try-restart fedora-loadmodules.service: Unit fedora-loadmodules.service not found.
warning: %post(dkms-2.6.1-5.noarch) scriptlet failed, exit status 5
Error in POSTIN scriptlet in rpm package dkms
Installed: dkms-2.6.1-5.noarch
Installed: dkms-virtualbox-5.2.22-1.x86_64
Installing : dkms-virtualbox-5.2.22-1.x86_64 3/3
Running scriptlet: dkms-virtualbox-5.2.22-1.x86_64 3/3
+ /usr/sbin/dkms --rpm_safe_upgrade add -m virtualbox -v 5.2.22-1
Creating symlink /var/lib/dkms/virtualbox/5.2.22-1/source ->
/usr/src/virtualbox-5.2.22-1
DKMS: add completed.
+ /usr/sbin/dkms --rpm_safe_upgrade build -m virtualbox -v 5.2.22-1
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area....(bad exit status: 2)
./vboxbuild /lib/modules/4.19.2-desktop-2omv4000/build........
/usr/sbin/dkms: line 1418: /var/lib/dkms/virtualbox/5.2.22-1///module/symvers.gz: No such file or directory
So apparently we need fedora-loadmodules.service? I’m wondering what made it go away I had it about a week or 10 days ago.
# systemctl status fedora-loadmodules.service
Unit fedora-loadmodules.service could not be found.
Note: Also even if dkms-virtualbox did work it is missing vboxpci module which according to @Colin we need in OpenMandriva for all VBox features to work. This needs to be looked at as well.
Note-2: make.log says “ERROR: Kernel configuration is invalid.”
Note: For most users of VirtualBox on your host machine only ‘vboxdrv’ is mandatory for VBox to work. I have verified that on a Cooker host machine. What the others are for (From Arch Linux wiki):
vboxnetadp and vboxnetflt are both needed when you intend to use the bridged or host-only networking feature. More precisely, vboxnetadp is needed to create the host interface in the VirtualBox global preferences, and vboxnetflt is needed to launch a virtual machine using that network interface.
vboxpci is needed when your virtual machine needs to pass through a PCI device on your host.
So for most users if for some reason VirtualBox kernel modules aren’t being loaded automatically then you should only need:
Yesterday on IRC @bero told me to remove the dkms stuff and this would be fixed in some script or scripts. Anyway I will update and reboot and report back shortly.
$ systemctl status loadmodules.service
● loadmodules.service - Load legacy module configuration
Loaded: loaded (/lib/systemd/system/loadmodules.service; enabled; vendor preset: enabled)
Active: inactive (dead)
Condition: start condition failed at Wed 2018-11-28 07:56:45 CST; 29s ago
├─ ConditionPathExists=|/etc/rc.modules was not met
└─ ConditionDirectoryNotEmpty=|/etc/sysconfig/modules was not met
This is with kernel:
$ uname -a
Linux ben79-pc 4.19.4-desktop-1omv4000 #1 SMP Mon Nov 26 15:19:10 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
More:
$ ls -la /etc/rc.modules
ls: cannot access '/etc/rc.modules': No such file or directory
$ ls -la /etc/sysconfig/modules
ls: cannot access '/etc/sysconfig/modules': No such file or directory
Post-edit: Possibly incorrect paths or file names?
