Lx 3 Installed from ISO # 1298 and fully updated. -
KDE/Plasma5 -
This is happening a lot in VirtualBox. What I specifically did in this instance was to open VirtualBox>File>Preferences and select OK. This will crash KWin every time I do it.
This is all ‘journalctl’ reports from the above instance:
$ journalctl -e
Jul 23 20:35:11 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29776, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:11 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29777, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:11 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29778, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:11 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29779, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:11 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29780, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:11 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29781, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:11 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29782, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:11 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29783, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:12 localhost.localdomain plasmashell[4598]: QXcbConnection: XCB error: 2 (BadValue), sequence: 59162, resource id: 33554454, major code: 143 (Unk
Jul 23 20:35:12 localhost.localdomain plasmashell[4598]: QXcbConnection: XCB error: 2 (BadValue), sequence: 59204, resource id: 69206037, major code: 143 (Unk
Jul 23 20:35:15 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31752, resource id: 33554472, major code: 18 (Chang
Jul 23 20:35:18 localhost.localdomain systemd-coredump[10221]: Core file was truncated to 2147483648 bytes.
Jul 23 20:35:20 localhost.localdomain systemd-coredump[10221]: Failed to generate stack trace: Unwinding not supported for this architecture
Jul 23 20:35:20 localhost.localdomain systemd-coredump[10221]: Process 10153 (kwin_x11) of user 1001 dumped core.
Jul 23 20:35:23 localhost.localdomain plasmashell[4598]: QXcbConnection: XCB error: 2 (BadValue), sequence: 59775, resource id: 62914589, major code: 143 (Unk
Jul 23 20:35:24 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 34545, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:24 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 34546, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:24 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 34547, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:24 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 34548, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:24 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 34549, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:24 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 34550, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:24 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 34551, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:24 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 34552, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:24 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 34717, resource id: 0, major code: 14 (GetGeometr
Jul 23 20:35:24 localhost.localdomain kwin_x11[10186]: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 34718, resource id: 0, major code: 14 (GetGeometr
Anyone have any idea what is going on with this? Does anyone else see this?
Does this indicate a problem?
Edit: Selecting OK in VBox Preferences isn’t the only thing that crashes KWin, it is just an example.
