_OpenMandriva Lx version:_OpenMandrivaLinux 3.0 Einsteinium
Desktop environment (KDE, LXQT…): LXQT, KDE
_Description of the issue (screenshots if relevant):_The installed ‘virtualbox-guest-additions’ give support only for Shared Folder, but not for Bidirectional Clipboard.
Following Message occur:
VBoxClient: VBoxClient (seamless): failed to start. Stage: Setting guest IRQ filter mask Error: VERR_INTERNAL_ERROR
- _Relevant informations (hardware involved, software version, logs or output…):_as VM in a VirtualBox 5.2.18
A solution as Workaround is:
1) Deinstall ‘virtualbox-guest-additions’
2) Install the Guestadditions 5.1.34 from the Oracle-ISO from
https://download.virtualbox.org/virtualbox/5.1.34/
with regards
Ch. Hanisch
