Virt-manager qemu/kmv lib64virt help
  • _**OpenMandriva Lx version: 24.12
  • _**Desktop environment (KDE, LXQT…): KDE
  • _**Description of the issue (screenshots if relevant): unable to start default network for libvirt
# virsh net-start default
error: Failed to start network default
error: Cannot find 'tc' in path: No such file or directory
  • _**Relevant information (hardware involved, software version, logs or output…): Just moved all my psychical devices to OMLX, I have this system were I was using promox but I want to start using OpenMandriva rolling with qemu/kvm and virt-manager as a lab, unfortunately when I try to start virtual networks or create a New one I get that error, been going around the libvirt manual but cannot find anything related to ‘tc’, anyone has faced this issues or something similar before?
# virsh --version
10.10.0
# qemu-system-x86_64 --version
QEMU emulator version 9.1.93 (qemu-9.2.0-0.rc3.1)
Copyright (c) 2003-2024 Fabrice Bellard and the QEMU Project developers
Hey @daemonx,
tc will be part of the iproute2-tc package.
I recently setup QEMU/KVM and it was one I had to hunt down. Let me know if that works.
oh man, that was so easy! why wouldn’t they add this to the manual, anyway, thanks for the help.
awesome! Are you getting the default network showing up now with virsh list?
yes up and running, and was able to create my own as well.
Hi!
It’s a small difference but, for me, running OM Lx ROME with Plasma, even after doing:
sudo dnf install virt-manager qemu qemu-kvm iproute2-tc
It would still not work me, as in I could not get the software to establish a connection.
It took installing iptables and a reboot to fix.
sudo dnf install iptables
Adding onto this since I didn’t think creating another topic just for this would be best. I hope it helps anyone with a similar situation. Cheers!
nice thanks for the info, the only small difference is I’m using firewalld
