Viber and WhatsApp are getting popular any ideas about those?
Viber
You can install it from here https://www.viber.com/products/linux/
Unfortunately Viber license does not allow to redistribute it by others, so it cannot be added to OpenMandriva repositories. Second Viber does not provide source code. -
WhatsApp
Does not have any linux client. You can use web client https://web.whatsapp.com/
I checked Viber but I can not install it. urpmi viber.rpm
gives an error. better check.
Well it’s not urpmi fault. Blame VIber, whos not allow anyone to redistribute it.
Can you please post output here ?
ok. but You have to wait till Friday.
Viber FB Feedback.
Supported platforms:
Read on to find out whether Viber will work with your phone, tablet or computer.
https://support.viber.com/customer/portal/articles/1354549-supported-platforms
[root@pujitha-pc Downloads]# urpmi viber.rpm
A requested package cannot be installed:
viber-6.5.5.1481-2.x86_64 (due to unsatisfied libcrypto.so.10()(64bit))
Continue installation anyway? (Y/n) y
While some packages may have been installed, there were failures.
Yes i’ve just installed that viber.rpm on my system.
[live@localhost viber]$ LC_ALl=C ./Viber
QSqlDatabasePrivate::removeDatabase: connection 'ConfigureDBConnection' is still in use, all queries will cease to work.
Qt WebEngine ICU data not found at /opt/viber/resources. Trying parent directory...
Qt WebEngine resources not found at /opt/viber/resources. Trying parent directory...
QQmlApplicationEngine failed to load component
qrc:/QML/LoginWizard/LoginWizard.qml:1 plugin cannot be loaded for module "QtQuick": Wtyczka "/usr/lib64/qt5/qml/QtQuick.2/libqtquick2plugin.so" używa niepoprawnej wersji biblioteki Qt. (5.8.0) [release]
This means viber.rpm is compiled against old Qt5 framework. We can not do much except talk to viber release its sources.
