Hello Happy User,
- OpenMandriva Lx version:
Cooker and ROME
Any
Usb connected HP Photosmart 6520 printer installs normally but does not print. If I reboot any jobs in print queue that were not completed print when operating system boots or desktop loads. (I think this part is weird.)
Workaround that worked for me. This workaround may work if you have a problem with other usb connected printer.
Use CUPS (type localhost:631 in url bar of browser) to remove printer
Remove
usbmuxdandipp-usb$ sudo dnf rm usbmuxd ipp-usb -
Reboot
Use CUPS to reinstall printer and print test page
Note: This should work with SystemSettings>Hardware>Printers or from command line:
$ kcmshell5 kcm_printer_manager
Note-2: Removing ipp-usb means you won’t be able to use driverless driver. (Yes, sounds like an oxymoron.)
