Unable to run virtual camera with obs
Hyprland 0.53.3
When i try to launch obs’s virtual camera, obs goes to 0mb ram usage and i can’t access the camera until after a full reboot.
when i try to run the flatpak obs i get the same problem.
i tried it on two laptops, both with v4l-utils installed (removed edid-decode since there was a conflict)
i’d assume the problem is with accessing the virtual cam.
Same problem happens if i kill telegram after/while sharing screen.
also, when i launch virt cam in obs then launch telegram and open a call, also telegram goes to 0mb ram usagee
(forgot to mention but using btop for usage info)
same problem on KDE wayland and x11
all packages are up to date.
this issue might be related
Hi, command “akmods --force --verbose” in command line (*bash) to create new and actual modules … i don’t remember i get this for this site but is need to correctly work in webcam (in my case, i have artifact when any applications for cam are work). First clean old modules driver from kernel path. If not, i read is need to get v4l2 from git and create (*build) own driver to close properly kernel without any errors in log.
