Dopo gli aggiornamenti dell’11/09/2017 c’è una novità, a parte il problemino risolto da Christopher_tanner.
Durante il caricamento compare schermata fissa con la scritta di cui sopra.
Anche premendo [ESC] non c’è variazione.
Alla fine si arriva comunque alla schermata di login come solito.
Sotto il passaggio da prima a dopo aggiornamento…
# journalctl | grep microcode
set 04 07:30:56 openmandriva kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 04 07:30:56 openmandriva kernel: microcode: Microcode Update Driver: v2.2.
set 05 07:52:27 openmandriva kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 05 07:52:27 openmandriva kernel: microcode: Microcode Update Driver: v2.2.
set 06 07:39:47 openmandriva kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 06 07:39:47 openmandriva kernel: microcode: Microcode Update Driver: v2.2.
set 07 07:13:47 openmandriva kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 07 07:13:47 openmandriva kernel: microcode: Microcode Update Driver: v2.2.
set 08 07:53:09 openmandriva kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 08 07:53:09 openmandriva kernel: microcode: Microcode Update Driver: v2.2.
set 08 17:59:05 openmandriva kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 08 17:59:05 openmandriva kernel: microcode: Microcode Update Driver: v2.2.
set 09 08:11:35 openmandriva kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 09 08:11:35 openmandriva kernel: microcode: Microcode Update Driver: v2.2.
set 09 19:12:23 openmandriva kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 09 19:12:23 openmandriva kernel: microcode: Microcode Update Driver: v2.2.
set 10 08:38:42 openmandriva kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 10 08:38:42 openmandriva kernel: microcode: Microcode Update Driver: v2.2.
set 11 07:40:07 openmandriva kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 11 07:40:07 openmandriva kernel: microcode: Microcode Update Driver: v2.2.
set 11 08:15:56 kernel: [Firmware Bug]: TSC_DEADLINE disabled due to Errata; please update microcode to version: 0x22 (or later)
set 11 08:15:56 kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 11 08:15:56 kernel: microcode: Microcode Update Driver: v2.2.
set 12 07:34:42 kernel: [Firmware Bug]: TSC_DEADLINE disabled due to Errata; please update microcode to version: 0x22 (or later)
set 12 07:34:42 kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 12 07:34:42 kernel: microcode: Microcode Update Driver: v2.2.
set 12 19:11:29 kernel: [Firmware Bug]: TSC_DEADLINE disabled due to Errata; please update microcode to version: 0x22 (or later)
set 12 19:11:29 kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 12 19:11:29 kernel: microcode: Microcode Update Driver: v2.2.
set 12 21:29:58 kernel: [Firmware Bug]: TSC_DEADLINE disabled due to Errata; please update microcode to version: 0x22 (or later)
set 12 21:29:58 kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 12 21:29:58 kernel: microcode: Microcode Update Driver: v2.2.
set 13 07:13:06 kernel: [Firmware Bug]: TSC_DEADLINE disabled due to Errata; please update microcode to version: 0x22 (or later)
set 13 07:13:06 kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 13 07:13:06 kernel: microcode: Microcode Update Driver: v2.2.
set 14 07:58:02 kernel: [Firmware Bug]: TSC_DEADLINE disabled due to Errata; please update microcode to version: 0x22 (or later)
set 14 07:58:03 kernel: microcode: sig=0x306c3, pf=0x10, revision=0x16
set 14 07:58:03 kernel: microcode: Microcode Update Driver: v2.2.
Sembra che sia richiesto un aggiornamento…
Qualcuno riesce a darmi chiarimenti?
[~]$ inxi -F
System: Kernel: 4.13.0-desktop-1omv x86_64 (64 bit) Desktop: KDE Plasma 5.10.4
Distro: OpenMandrivaLinux 3.0 Einsteinium
Machine: System: TOSHIBA product: SATELLITE C55-A-1P6 v: PSCGNE-00V00FIT
Mobo: TOSHIBA model: PT10S Bios: TOSHIBA v: 1.20 date: 01/13/2014
CPU: Dual core Intel Core i5-4200M (-HT-MCP-) cache: 3072 KB
clock speeds: max: 3100 MHz 1: 2494 MHz 2: 2494 MHz 3: 2494 MHz 4: 2494 MHz
Graphics: Card-1: Intel 4th Gen Core Processor Integrated Graphics Controller
Card-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M]
Display Server: OpenMandriva X.org 119.3 driver:
GLX Renderer: Mesa DRI Intel Haswell Mobile GLX Version: 3.0 Mesa 17.1.8
Audio: Card-1 Intel 8 Series/C220 Series High Definition Audio Controller driver: snd_hda_intel
Card-2 Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.13.0-desktop-1omv
Network: Card-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter driver: ath9k
IF: wlp3s0 state: down
Card-2: Qualcomm Atheros QCA8172 Fast Ethernet driver: alx
IF: enp4s0 state: up speed: 100 Mbps
Drives: HDD Total Size: 500.1GB (26.1% used) ID-1: /dev/sda model: HGST_HTS545050A7 size: 500.1GB
