This is meant to describe how things actually work today in OM Lx installations.
In Manual Partitioning especially when combined with multi-booting there are to many variables and to many possible scenarios to cover every aspect.
These suggestions are based on input from users and testers.
At this time partitioning LVM and Raid setups with Calamares (the installer) are NOT supported.
This section needs updating (2025-05-12). As of release of OM Lx 4.1 LUKS partitioning is not well supported. We see people using and people saying that it does not work. This support should be fixed for release of OM Lx 4.2. Edit: As of 2025-05-12 LUKS is better supported but does not seem straightforward.
Note: This applies to all partitioning, all installation on hardware: If you have a UEFI/EFI computer and your BIOS offers a choice when you boot installation media between for example:
USB some Flash Drive
UEFI USB some Flash Drive
or
some DVD optical_device
UEFI some DVD optical_device
You have to choose the UEFI option and boot that. But know also that not all computers will do this. Some with more spartan BIOS will offer only the one option and almost always it is the correct one. So for instance if on a notebook you donāt see the above choice no worries.
If you have multiple storage drives enabled they all need to have the same partition table type. They either need to all be gpt or all mbr for everything to work properly.
On UEFI computers in multi-boot situation with multiple storage drives if you already have an existing /boot/efi partition you should use that. Do not format you just set the mount point to ā/boot/efiā on the existing partition and be sure the boot flag is selected. One can have many different boot loaders for different operating systems in the same
/boot/efipartition. If there is any need to switch boot loaders that is done in UEFI/BIOS settings. Many people do not seem to understand that the files in/boot/efiare one line files, they are tiny.
Always be aware if you are using Manual Partitioning we assume that you know what you are doing and that you have some ability to problem solve and correct errors yourself. If you do have problems you canāt resolve try to keep in mind when you post any information that you donāt know what information the person trying to help you solve your issue needs. So donāt fall in to the lazy āIāll just post the part I think they needā. Be detailed. If you are posting terminal output post all of it. If there is a lot of output place that in a .txt file and post the .txt file in bug report or forum thread. You should post screen shots of what you were trying to do and any error message. You may be asked to post installation log and other information like hardware, ect. How To do that is described in more detail here.
