Hanisch
(Ch. Hanisch)
April 11, 2024, 3:50pm
1
_OpenMandriva Lx version: _ROME
_Desktop environment (KDE, LXQT…): _LXQT
after Update like Upgrading/distro-sync ROME (2024-04-20)
tint2 don’t work.
$ tint2
tint2: Using glib slice allocator (default). Run tint2 with environment variable G_SLICE=always-malloc in case of strange behavior or crashes
tint2: xShm: Disabled
tint2: xRandr: Found crtc's: 8
tint2: xRandr: Linking output Virtual1 with crtc 0, resolution 1280x768, DPI 96
tint2: xRandr: crtc 1 seems disabled
tint2: xRandr: crtc 2 seems disabled
tint2: xRandr: crtc 3 seems disabled
tint2: xRandr: crtc 4 seems disabled
tint2: xRandr: crtc 5 seems disabled
tint2: xRandr: crtc 6 seems disabled
tint2: xRandr: crtc 7 seems disabled
tint2: No XSETTINGS manager, tint2 uses config option 'launcher_icon_theme'.
tint2: Loading config file: /home/opa/.config/tint2/tint2rc
tint2: real transparency off.... depth: 24
tint2: panel items: (null)
tint2: Systray composited rendering on
Speicherzugriffsfehler (Speicherabzug geschrieben)
Hoe can I repair that?
with regards
Ch. Hanisch
ben79
(Ben Bullard)
April 11, 2024, 4:40pm
2
My guess is tint2 package needs to be rebuilt and currently tint2 builds fail, indicating some problem, so I passed along that in OpenMandriva Cooker Chat channel for the developer.
ben79
(Ben Bullard)
April 12, 2024, 3:48pm
3
I do not use tint2, don’t know anything about it, but one of the OM devs got the package built for cooker and it seems to do something:
Package build is started for ROME/rolling.
Edit : When it finishes publishing to rolling repositories it will be tint2-17.1.3-3. Should be available for x86_64 and znver1 systems in a few hours.
Hanisch
(Ch. Hanisch)
April 13, 2024, 2:38pm
4
after last update:
$ rpm -qa tint2
tint2-17.1.3-3.x86_64
But
$ tint2
````Vorformatierter Text`
with regards
Ch. Hanisch
ben79
(Ben Bullard)
April 19, 2024, 10:17pm
5
This is not being ignored. Developers are just very busy with Plasma5>Plasma6 stuff and that has resulted in a lot of things that need fixing. Typical for any KDE Plasma major upgrade.
Devs are also working on upgraded packages for LXQt.
system
(system)
Closed
May 19, 2024, 10:18pm
6
