Temporary fix Apparmor in OpenMandriva (sudo dnf in apparmor)
Sorry I misbehaved last time. The solution is :
sudo dnf rm iputils
and
I suspect and chatgpt that Because apparmor is trying to install the same file
(/etc/apparmor.d/bin.ping)
I don’t really see any other way to avoid this error and I don’t know much about why it happens.
I hope the OpenMandriva team will fix this bug in the next version of Rock.
:white_check_mark: I have Searched the forum for my issue and found nothing related or helpful
:white_check_mark: I have checked the Resources category (Resources Index)
:white_check_mark: I have reviewed the Wiki for relevant information
:white_check_mark: I have read the the Release Notes and Errata
KDE Plasma Version 6.3.4
Package                 Architecture          Version                 Repository                        Size
Installing:
apparmor                x86_64                4.0.3-2                 rock-x86_64-extra                772 k
Transaction Summary
Install  1 Package
Total download size: 772 k
Installed size: 2.5 M
Is this ok \[y/N\]: y
Downloading Packages:
apparmor-4.0.3-2-omv2490.x86_64.rpm                                           343 kB/s | 772 kB     00:02
Total        342 kB/s | 772 kB     00:02
Running transaction check
Transaction check succeeded.
Running transaction test
You can remove cached packages by executing ‘dnf clean packages’.
Error: Transaction test error:
file /etc/apparmor.d/bin.ping from install of apparmor-4.0.3-2.x86_64 conflicts with file from package iputils-20221126-1.x86_64
A hint:
Resources Index
[Forum] How to post code as code
Edit: This is courtesy to everyone else and an asset to problem solving, it is a lot easier to read code posted as code.
I edited the content.
@FernPolskaOriginal next time(s) please use the preformatted text for code, thank you.
I don’t see the “fix” or the “solution” when you say you don’t know how to avoid the error. It looks like a packaging bug. I would also suggest you don’t use AI to solve problems with our distro. They aren’t going to train their AI to bother with it.
