Telegram does not have stickers and animated stickers
hello, seems like on my install (openmadriva rock 6.0 gnome) telegram misses most stickers + animated stickers, and some emojis too
there is an option in settings for downloading emojis packs but it just does nothing
i think the correct emojis packs are installed so it should be fine, but still
does anybody have suggestions on how to fix that?
for the record telegram is the one shipped by openmandriva…
For now, please use the flatpak.
are you saying me that there is no solution at the moment?like for the broken night theme?because that would still answer my question and i could mark it as solved
Because of how they build things and the library versions they package with it, there are broken features. Newer versions add more libraries, as well. The tdlib E2EE feature was broken when this was last looked at. It would be pointless to bring in an entire library and only build one section of it just for Telegram. The library also will not plan to have formal releases, so we must package against master.
You can follow the progress here:
The best thing to do for now is use flatpak.
