Previously working Telegram desktop installed from dnfdragora will not complete loading process. Launching the program from menu = tab with icon appears momentarily with spinner, then disappears with no further explanation.
I have tried removing & reinstalling with dnfdragora, same result.
The program did load previously and was in use for several months, no known changes initiated.
Telegram desktop 2.4.8 from package repository (dnfdragora)
|10/28/21 2:51 PM|systemd|Started Telegram Desktop - Telegram Desktop.|
|10/28/21 2:51 PM|systemd|app-telegramdesktop-efbf4f2eb53a42339e257ddfa7ffabad.scope: Succeeded.|
|10/28/21 2:51 PM|kwin_x11|qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59744, resource id: 10486391, major code: 18 (ChangeProperty), minor code: 0|
|10/28/21 2:51 PM|plasmashell|file:///usr/share/plasma/plasmoids/org.kde.plasma.kicker/contents/ui/ItemListDialog.qml:51: TypeError: Cannot read property ‘separatorCount’ of null|
|10/28/21 2:51 PM|plasmashell|trying to show an empty dialog|
|10/28/21 2:52 PM|kernel|[UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:01:94:10:3e:f7:ba:12:08:00 SRC=192.168.2.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2 |
|10/28/21 2:52 PM|kernel|[UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:c0:d2:f3:f3:87:92:08:00 SRC=192.168.2.2 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2 |
Your system is probably using ufw not firewalld. This is what I found on OM Lx 4.2 systems I have:
# systemctl status firewalld
Unit firewalld.service could not be found.
# systemctl status ufw
● ufw.service - Uncomplicated firewall
Loaded: loaded (/lib/systemd/system/ufw.service; enabled; vendor preset: enabled)
Active: active (exited) since Thu 2021-10-28 22:03:56 CDT; 3min 32s ago
Docs: man:ufw(8)
man:ufw-framework(8)
file://usr/share/doc/ufw/README
Process: 640 ExecStart=/usr/libexec/ufw/ufw-init start (code=exited, status=0/SUCCESS)
Main PID: 640 (code=exited, status=0/SUCCESS)
Oct 28 22:03:55 vbox-Z-3767 systemd[1]: Starting Uncomplicated firewall...
Oct 28 22:03:56 vbox-Z-3767 systemd[1]: Finished Uncomplicated firewall.
I thought the default was supposed to be Allow for Incoming and Outgoing but my systems were set to Deny also. I have asked developers about this on IRC.
You could try setting incoming to Allow and see if Telegram works again.
● firewalld.service - firewalld - dynamic firewall daemon
Loaded: loaded (/lib/systemd/system/firewalld.service; disabled; vendor preset: enabled)
Active: inactive (dead)
Docs: man:firewalld(1)
Here is the UFW status:
Active: active (exited) since Thu 2021-10-28 14:39:15 PDT; 6h ago
Docs: man:ufw(8)
Process: 781 ExecStart=/usr/libexec/ufw/ufw-init start (code=exited, status=0/SUCCESS)
Main PID: 781 (code=exited, status=0/SUCCESS)
From a quick look at the links you provided, deny incoming is default.
To my knowledge, I have not intentionally changed the default settings, and the Telegram desktop program was working successfully since the most recent installation of the OM LX 4.2 O/S.
I’m curious and concerned about possible adverse effects of re-setting the default to allow, and also how this was changed to become non-functional.
Also, gufw - the GUI front end is not available in repository, any ideas if this might be included in the future?
Changed Incoming from Deny to Allow, made no difference, Telegram launch still fails in same manner, so I reset to Deny
Telegram might have done something that disables old clients – may be worth trying to install the telegram-desktop package from cooker
Edit: The telegram-desktop package in cooker will not install in OM Lx 4.2 so that option won’t work.
The idea about the firewall was a guess. And not necessarily a very good guess because OM has not done anything to the firewall that I know of since Lx 4.2 was released.
Here telegram-desktop in OM Lx 4.2 does not open with this output:
$ telegram-desktop
(process:1848): Telegram-WARNING **: 12:27:01.105: GTK integration was disabled on build or in runtime. This will lead to clipboard issues and a lack of some features (like Auto-Night Mode or system window cont
rols layout).
(process:1848): Telegram-WARNING **: 12:27:01.106: Application was built without embedded fonts, this may lead to font issues.
telegram-desktop: symbol lookup error: telegram-desktop: undefined symbol: SHA1, version OPENSSL_3.0.0
Edit: So something to do with openssl may be the culprit. If that is so then it won’t be fixed in OM Lx 4.2 but will be fixed for Lx 4.3.
[root@michael-ms7721 bin]# telegram-desktop
(process:31665): Telegram-WARNING **: 15:03:41.419: GTK integration was disabled on build or in runtime. This will lead to clipboard issues and a lack of some features (like Auto-Night Mode or system window controls layout).
(process:31665): Telegram-WARNING **: 15:03:41.422: Application was built without embedded fonts, this may lead to font issues.
QStandardPaths: runtime directory '/run/user/1001' is not owned by UID 0, but a directory permissions 0700 owned by UID 1001 GID 1006
