Synology Drive Client Flatpak issue
Hello OM Community,
i’m new to OM, installed Rock 6.0 but run into one issue. I have an Synology NAS and i used Synology Drive Client for file synchronisation. Synolgy only privides an .deb package.
So no problem under debian or it’s derivitives.
Arch has an package in the AUR the, if i understand the pkgbuild file right, only downloads the original .deb file from Synology an unpacks it to the local system.
Third way is an unofficial Flatpak. I installed this several times under debian and arch and it works there. Under OM i get an error ( see below )
Any Ideas ? Or is there a other way to get it running under OM ?
Thank you and greetings from germany
Andreas
I have [Searched]the forum for my issue and found nothing related or helpful
Rock 6.0 Wayland
KDE
I’ve installed Synology Drive as Flatpak but it’s not running.
If i start it via console i get this:
flatpak run com.synology.Synologydrive
Fehler: app/com.synology.Synologydrive/x86_64/master ist nicht installiert
When i run installation again i get this:
flatpak install flathub com.synology.SynologyDrive
Suchen nach Übereinstimmungen …
Wird übersprungen: com.synology.SynologyDrive/x86_64/stable wurde bereits installiert
Thinkpad T14 gen1 AMD Ryzen7 16GB Ram
@kaac128
welcome1
Ok, seems to be an Wayland problem.
I reinstalled OM with X11 and the Flatpak works fine …
