Super key + p do not work plasma 6 OM 6
OpenMandriva Lx version:6
Logo windows p super p does nothing.
Yet it is present in shortcut settings.
Please view the screen attached to the post
Desktop environment (KDE…):
I thought that if I hard reset kde settings it will start to work but no, it doesn’t
rm -Rfv ~/.config/plasma-org.kde.plasma.desktop-appletsrc ~/.config/plasmashellrc
So i create a custom combination super shift p still nothing
I’m relaying gravely on this simple function due to work on two monitors.
Im in need of constant switching and extending my display between those two monitors. By now I have a cloned view from monitor 0 on monitor 1
I can verify this. The shortcut is there by default, but doesn’t do anything.
EDIT: This already has a bug report filed on the KDE Bug Tracker.
502486 – Shortcut for Display Configuration does not work anymore due to dbus communication issues
This little bugger cripples my workflow badly. I will try to install Xfce and see what that does.
If it works great if not. Well I do not know.
That beeing siad instaling a separate desktop shoud not be a solution for “zombie shortcuts”
Status: RESOLVED FIXED
Alias: None
Product: KScreen
Component: OSD and Plasma applet (show other bugs)
**Version: 6.3.4
Version Fixed In: 6.3.5
Ok I will wait we have plasma 6.3.4 for the time beeing
Take a look here. There is a work around that may help for the time being. Since the bug report exists, it won’t be long till they have it fixed.
Switching between display modes using Meta+P does not work - Help - KDE Discuss
If something look stupid, but it works, then it ain’t stupid at all.
Thank you, @WilsonPhillips
A question. Is there a way to update to plasma 6.3.5 on open mandriva 6 stable?
Or this version is only available on rome / cooker
Currently, installed plasma version after clean official iso install on rock is 6.3.4
You’re a bit ahead of the time there… 6.3.5 will be released next Tuesday, May 6.
https://community.kde.org/Schedules/Plasma_6
Until then you won’t even get it in Cooker.
Woo Hoo, I thought that they fix it, not that they plan to fix it in next minor release. :slight_smile:
Thank you for taking time to replay. OK, then I’ll just wait.
Take care @bero
