NONE(related to boot of livegui)
When I press Enter to start the livegui on the GRUB menu everything is frozen, my mouse leds are on but the red laser is off, the USB stick is blicking indicating reads and then stop, I’m stuck with a background of the GRUB menu and nothing works. The ISO is not corrupted, SHA1 matches perfectly.
My Hardware :
CPU : Intel Core i5-12450H 8C/12T 4.4GHz.
RAM : 32GB DDR5 4800MHz.
GPU : NVidia RTX 4060 8GB Laptop GPU.
Storage : Western Digital SN770 1TB, TBW Endueance : 600TB
OpenMandriva has no employees. It consists of a small group of all volunteer, unpaid, part-time, developers and other contributors - and we all wish there were more of us.
As a Community distribution of Linux we depend on community members to help solve issues and make things better.
I can’t reproduce this on any of my hardware, but my guess would also be that it’s related to the nvidia GPU, their Linux support is horrible.
If your BIOS has such an option, can you try switching between the integrated and the external GPU?
If not, do any of the boot options under Troubleshooting in the grub menu work?
Does a current cooker snapshot work? (There have been a few firmware updates that could be related).
Yep, it was related to the nvidia GPU…
I simply disabled it in the BIOS and it works now, I’ll update my system after installation and maybe re-enable the nvidia gpu… because i heard intel igpu works better than nvidia gpus under linux(not performance wise but more bugs and stability wise)
