DISTRIB_RELEASE=23.01
DISTRIB_CODENAME=ROME
DISTRIB_DESCRIPTION=“OpenMandriva Lx 23.01” -
Plasma, but seems irrelevant. -
Strange errors when upgrading. -
It doesn’t seem to prevent me to work, but in case here is what I’ve got as output with dnf.
[raphael@fleur ~]$ sudo LC_ALL=C dnf update
Last metadata expiration check: 0:04:25 ago on Thu Feb 9 23:21:28 2023.
Dependencies resolved.
Problem 1: cannot install both lib64boost_filesystem-1.81.0-1.x86_64 and lib64boost_filesystem-1.80.0-2.x86_64
- package lib64OpenImageIO_Util2.3-2.3.19.0-1.x86_64 requires libboost_filesystem.so.1.80.0()(64bit), but none of the providers can be installed
- cannot install the best update candidate for package lib64boost_filesystem-1.80.0-2.x86_64
- problem with installed package lib64OpenImageIO_Util2.3-2.3.19.0-1.x86_64
Problem 2: cannot install both lib64boost_thread-1.81.0-1.x86_64 and lib64boost_thread-1.80.0-2.x86_64
- package lib64OpenImageIO2.3-2.3.19.0-1.x86_64 requires libboost_thread.so.1.80.0()(64bit), but none of the providers can be installed
- cannot install the best update candidate for package lib64boost_thread-1.80.0-2.x86_64
- problem with installed package lib64OpenImageIO2.3-2.3.19.0-1.x86_64
Problem 3: package lib64digikamcore-7.9.0-3.x86_64 requires liblensfun.so.1()(64bit), but none of the providers can be installed
- cannot install both lib64lensfun0-0.3.3-2.x86_64 and lib64lensfun0-0.3.95-1.x86_64
- cannot install the best update candidate for package lib64digikamcore7.8.0-7.8.0-3.x86_64
- problem with installed package lib64lensfun0-0.3.95-1.x86_64
Problem 4: package showfoto-7.9.0-3.x86_64 requires libdigikamcore.so.7.9.0()(64bit), but none of the providers can be installed
- package lib64digikamcore-7.9.0-3.x86_64 requires liblensfun.so.1()(64bit), but none of the providers can be installed
- package lib64digikamcore7.9.0-7.9.0-2.x86_64 requires liblensfun.so.1()(64bit), but none of the providers can be installed
- cannot install the best update candidate for package showfoto-7.8.0-3.x86_64
- cannot install the best update candidate for package lib64lensfun0-0.3.95-1.x86_64
Problem 5: package showfoto-7.9.0-3.x86_64 requires libdigikamcore.so.7.9.0()(64bit), but none of the providers can be installed
- problem with installed package showfoto-7.8.0-3.x86_64
- package showfoto-7.8.0-3.x86_64 requires digikam = 7.8.0-3, but none of the providers can be installed
- package showfoto-7.9.0-2.x86_64 requires digikam = 7.9.0-2, but none of the providers can be installed
- package lib64lensfun0-0.3.3-2.x86_64 requires lensfun = 0.3.3-2, but none of the providers can be installed
- cannot install both digikam-7.9.0-3.x86_64 and digikam-7.8.0-3.x86_64
- cannot install both digikam-7.9.0-3.x86_64 and digikam-7.9.0-2.x86_64
- cannot install both lensfun-0.3.3-2.x86_64 and lensfun-0.3.95-1.x86_64
- cannot install the best update candidate for package digikam-7.8.0-3.x86_64
- problem with installed package lensfun-0.3.95-1.x86_64
Problem 6: package lib64digikamgui-7.9.0-3.x86_64 requires libdigikamcore.so.7.9.0()(64bit), but none of the providers can be installed
- cannot install the best update candidate for package lib64digikamgui7.8.0-7.8.0-3.x86_64
- cannot install the best update candidate for package lensfun-0.3.95-1.x86_64
Skipping packages with conflicts:
(add '--best --allowerasing' to command line to force their upgrade):
digikam x86_64 7.9.0-2 rolling-x86_64 13 M
digikam x86_64 7.9.0-3 rolling-x86_64 13 M
lensfun x86_64 0.3.3-2 rolling-x86_64 499 k
lib64boost_filesystem x86_64 1.81.0-1 rolling-x86_64 57 k
lib64boost_thread x86_64 1.81.0-1 rolling-x86_64 46 k
lib64lensfun0 x86_64 0.3.3-2 rolling-x86_64 51 k
Skipping packages with broken dependencies:
lib64digikamcore x86_64 7.9.0-3 rolling-x86_64 3.3 M
lib64digikamcore7.9.0 x86_64 7.9.0-2 rolling-x86_64 3.3 M
lib64digikamgui x86_64 7.9.0-3 rolling-x86_64 1.9 M
showfoto x86_64 7.9.0-2 rolling-x86_64 662 k
showfoto x86_64 7.9.0-3 rolling-x86_64 662 k
Transaction Summary
Skip 11 Packages
Nothing to do.
Complete!
