(medium "non-free updates")
flash-player-plugin 27.0.0.170 1 omv 2015.0 x86_64
flash-player-plugin-kde 27.0.0.170 1 omv 2015.0 x86_64
1.2KB of additional disk space will be used.
17KB of packages will be retrieved.
Proceed with the installation of the 2 packages? (Y/n) Y
Error: Unable to download Flash Player. This is likely due to this package
being too old. Please file a bug report at https://issues.openmandriva.org
so that the package gets updated. Thank you.
In the meantime, you can download Flash Player manually from
http://get.adobe.com/flashplayer/
ERROR: 'script' failed for
error: %pre(flash-player-plugin-27.0.0.170-1.x86_64) scriptlet failed, exit status 1
error: install: %pre scriptlet failed (2), skipping flash-player-plugin-27.0.0.170-1.x86_64
error: %pre(flash-player-plugin-kde-27.0.0.170-1.x86_64) scriptlet failed, exit status 1
error: install: %pre scriptlet failed (2), skipping flash-player-plugin-kde-27.0.0.170-1.x86_64
This has happend again today (11/19/2017) in a Fresh install of Latest Lx 3.03 ISO # 1588.
error: %pre(flash-player-plugin-27.0.0.183-1.x86_64) scriptlet failed, exit status 1
error: install: %pre scriptlet failed (2), skipping flash-player-plugin-27.0.0.183-1.x86_64
Edit: This is a package installation from Konsole, Firefox is not involved.
# urpmi flash-player-plugin
This is a common recurring problem in OpenMandriva. It is a new version of flash-player-plugin trying to download the previous version of flash-player-plugin. Nothing to do with Firefox. This has happened before multiple times. I report it and it gets fixed.
In fact I’m reusing the thread from a previous instance of the same issue reported Oct. 25.
Edit: Current package is flash-player-plugin-27.0.0.183-1-omv2015.0.x86_64.rpm
I think it downloads the source.
Here’s an extract from the rpm spec file.
NOTE: This package does not contain the Flash Player itself. The
software will be automatically downloaded from Adobe during package
installation.
I suspect as soon as there is a new version the old version is removed.
Since the downloads requires a version number to be entered manually the package effectively expires.
Colin this has happened numerous times. The new package won’t download flash-player-plugin because it is calling for the wrong version:
Error: Unable to download Flash Player. This is likely due to this package being too old. Please file a bug report at https://issues.openmandriva.org
This happens over and over.
Edit: Ever time previous it was because something did not get changed in OpenMandriva’s package when someone updated our package.
Ben I know it’s a recurring problem but there’s nothing OpenMandriva can do about it. The version number is fixed in the rpm spec file but Adobe update the version the download url becomes invalid and we have to edit the rpm spec file to contain the new version number and then rebuild the rpm. There is no way to automate this because the sourcecode is not available; all we can do is fetch an rpm from Adobe and install the necessary dependencies.
I will try and find out the lates version number and update and rebuild the rpm.
For fruther illumination on this issue the urpmi output:
Downloading from http://fpdownload.macromedia.com/get/flashplayer/pdc/27.0.0.187/flash-player-npapi-27.0.0.187-release.x86_64.rpm:
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 8790k 100 8790k 0 0 8790k 0 0:00:01 --:--:-- 0:00:01 14.6M
Downloading from http://fpdownload.macromedia.com/get/flashplayer/current/licensing/linux/flash-player-npapi-27.0.0.187-release.x86_64.rpm:
100 286 100 286 0 0 286 0 0:00:01 --:--:-- 0:00:01 1481
Downloading from http://linuxdownload.adobe.com/linux/x86_64/flash-player-npapi-27.0.0.187-release.x86_64.rpm:
100 8790k 100 8790k 0 0 976k 0 0:00:09 0:00:09 --:--:-- 1012k
error: %pre(flash-player-plugin-27.0.0.187-1.x86_64) scriptlet failed, exit status 1
error: install: %pre scriptlet failed (2), skipping flash-player-plugin-27.0.0.187-1.x86_64
error: %pre(flash-player-plugin-kde-27.0.0.187-1.x86_64) scriptlet failed, exit status 1
error: install: %pre scriptlet failed (2), skipping flash-player-plugin-kde-27.0.0.187-1.x86_64
Appears to show that our script is attempting to download the correct (latest) version of flash-player-npapi and that there is indeed something that downloads. Yet our script says that Download failed even though 1012k of something just got downloaded. So I don’t know what about this is failing. Sometimes I’m just not smart enough.
Edit: The URL the script is using is definitely valid, it will download manually. So I’m baffled why the script still keeps saying: Error: Unable to download Flash Player.
