I use OpenMandrivaLinux 4.2 Argon I would like to install ‘Arial’ font in my system. I tried to search
[root@jeevanism-81d2 jeevanism]# dnf search ttf-mscorefonts
Last metadata expiration check: 3:01:42 ago on Fri 26 Mar 2021 10:25:14 GMT.
No matches found.
[root@jeevanism-81d2 jeevanism]# dnf search arial
Last metadata expiration check: 3:02:39 ago on Fri 26 Mar 2021 10:25:14 GMT.
====================================== Name Matched: arial ======================================
texlive-actuarialangle.noarch : Symbol for use in "present value" statements of an annuity
so I dont find Arial font in repo, is there anyway I can install this ?
[UPDATE - Solved]
I found a solution : I download this package from OpenSuse and install using DNF. It seems working now, I can access this font Arial in my Gimp and LibreOffice.
thank you.
