I installed KiCad (https://www.kicad.org/) using Flatpak. When I try to open old files few folders are visible.
and several are missed, including /mnt/ where I mount a partition containing my old files.
I don’t find any way to manual write path then KiCad is unusable.
I had other packages installed using Flatpak (Signal desktop) that works normally because it uses Dolphin to access files and directories.
_OpenMandriva Lx version:_4.3
Desktop environment (KDE, LXQT…): KDE
