I’m encountering this issue: YouTube browser > click on some link from the list
$ rpm -qa|grep smplayer
smplayer-16.11.0-1-omv2015.0.x86_64
$ rpm -qa|grep smtube
smtube-15.8.0-1-omv2015.0.x86_64
Error:
/usr/bin/mpv --no-config --no-quiet --terminal --no-msg-color --input-file=/dev/stdin --no-fs --hwdec=no --sub-auto=fuzzy --no-input-default-bindings --input-vo-keyboard=no --no-input-cursor --cursor-autohide=no --no-keepaspect --wid=69206041 --monitorpixelaspect=1 --osd-scale=1 --sub-ass --embeddedfonts --sub-ass-line-spacing=0 --sub-scale=1 --sub-font=Arial --sub-color=#ffffffff --sub-shadow-color=#ff000000 --sub-border-color=#ff000000 --sub-border-size=0.75 --sub-shadow-offset=2.5 --sub-codepage=utf8:ISO-8859-1 --sub-pos=100 --volume=55 --cache=auto --osd-level=0 --screenshot-template=cap_%F_%p_%02n --screenshot-format=jpg --screenshot-directory=/home/ruru/Pictures/smplayer_screenshots --audio-pitch-correction=yes --af-add=equalizer=0:0:0:0:0:0:0:0:0:0 --volume-max=110 --ytdl=no --term-playing-msg=MPV_VERSION=${=mpv-version:}
INFO_VIDEO_WIDTH=${=width}
INFO_VIDEO_HEIGHT=${=height}
INFO_VIDEO_ASPECT=${=video-aspect}
INFO_VIDEO_FPS=${=container-fps:${=fps}}
INFO_VIDEO_FORMAT=${=video-format}
INFO_VIDEO_CODEC=${=video-codec}
INFO_AUDIO_FORMAT=${=audio-codec-name}
INFO_AUDIO_CODEC=${=audio-codec}
INFO_AUDIO_RATE=${=audio-params/samplerate}
INFO_AUDIO_NCH=${=audio-params/channel-count}
INFO_LENGTH=${=duration:${=length}}
INFO_DEMUXER=${=current-demuxer:${=demuxer}}
INFO_SEEKABLE=${=seekable}
INFO_TITLES=${=disc-titles}
INFO_CHAPTERS=${=chapters}
INFO_TRACKS_COUNT=${=track-list/count}
METADATA_TITLE=${metadata/by-key/title:}
METADATA_ARTIST=${metadata/by-key/artist:}
METADATA_ALBUM=${metadata/by-key/album:}
METADATA_GENRE=${metadata/by-key/genre:}
METADATA_DATE=${metadata/by-key/date:}
METADATA_TRACK=${metadata/by-key/track:}
METADATA_COPYRIGHT=${metadata/by-key/copyright:}
INFO_MEDIA_TITLE=${=media-title:}
--term-status-msg=STATUS: ${=time-pos} / ${=duration:${=length:0}} P: ${=pause} B: ${=paused-for-cache} I: ${=core-idle} http://r4---sn-hpa7zned.googlevideo.com/videoplayback?ip=87.2.104.197&itag=22&key=yt6&mime=video/mp4&mt=1483905087&mv=m&nh=IgpwcjA0Lm1pbDAxKgw3Mi4xNC4yMDQuNzM&ms=au&mm=31&mn=sn-hpa7zned&pl=18&id=o-ADP-jOTnyvgBoEzMBjnx54QgAmbJY7GKSAVcVDESd8bW&dur=271.046&sparams=dur,id,initcwndbps,ip,ipbits,itag,lmt,mime,mm,mn,ms,mv,nh,pl,ratebypass,source,upn,expire&ipbits=0&ratebypass=yes&expire=1483926999&lmt=1483859455503560&upn=wYo79OjpFfA&initcwndbps=465000&quality=hd720&source=youtube&signature=19206A1DDB1EF18978CBDC1E7EEF16494C1EDDD4.59303A558868629FC73347C1B17FA340B57E3933
libx265.so.95: cannot open shared object file: No such file or directory
libx265.so.95 is missing, x265 support will be disabled
ffmpeg library versions:
libavutil 55.17.103 (runtime 55.34.100)
libavcodec 57.24.102 (runtime 57.64.101)
libavformat 57.25.100 (runtime 57.56.100)
libswscale 4.0.100 (runtime 4.2.100)
libavfilter 6.31.100 (runtime 6.65.100)
libswresample 2.0.101 (runtime 2.3.100)
ffmpeg version: 3.2.2
mpv was compiled against a different version of FFmpeg/Libav than the shared
library it is linked against. This is most likely a broken build and could
result in misbehavior and crashes.
mpv does not support this configuration and will not run - rebuild mpv instead.
Exiting... (Fatal error)
Console log:
[ruru@omlx-766 ~]$ smplayer
This is SMPlayer v. 16.11.0 (revision 8242) running on Linux
Warning: libpng warning: iCCP: known incorrect sRGB profile
Warning: PlayerProcess::writeToStdin: process not running
(smtube:4362): Gtk-WARNING **: Unable to locate theme engine in module_path: "adwaita",
Translations path: "/usr/share/smtube/translations"
Creating "/home/ruru/.config/smtube"
Sig::load
Sig::load
BrowserWindow::loadConfig
BrowserWindow::loadConfig: cache enabled. Location: "/home/ruru/.cache//smtube"
Players::load
Players::availablePlayers: 0 : "smplayer"
Players::availablePlayers: 1 : "smplayer"
Players::availablePlayers: 2 : "smplayer"
Players::availablePlayers: 4 : "vlc"
Players::availablePlayers: 8 : "mpv"
Players::availablePlayers: 9 : "mpv"
MyCookieJar::load
MyCookieJar::load: 0 cookies loaded
ytcode_file: "/home/ruru/.config/smplayer/yt.js"
BrowserWindow::adjustLocation: "http://www.tonvid.com/"
MyWebView::mousePressEvent: link: "http://www.youtube.com/watch?v=XGcX5wopq3M"
MyWebView::mousePressEvent: target: ""
BrowserWindow::processLink: "http://www.youtube.com/watch?v=XGcX5wopq3M"
BrowserWindow::openWith: player: "SMPlayer" url: "http://www.youtube.com/watch?v=XGcX5wopq3M"
BrowserWindow::openWith: player_id: 0 url: "http://www.youtube.com/watch?v=XGcX5wopq3M"
BrowserWindow::openWith: ready to play with "SMPlayer"
BrowserWindow::openWith: command: "smplayer "http://www.youtube.com/watch?v=XGcX5wopq3M""
MyWebView::mousePressEvent: link: ""
BrowserWindow::saveConfig
Players::save
MyCookieJar::save
MyCookieJar::save: "country"
[ruru@omlx-766 ~]$
PS>
This is 766 but the same happened with older ISOs
