SLiM Display Manager
Desktop environment (LXQT:
I was wondering how you would switch from Lightdm to Slim display manager. For SDDM to Lightdm it was as simple as an uninstall and install, but for slim that did not work. Is there a way to use slim instead of lightdm. I am just trialing different login/display managers
You may need to enable the service in systemd and disable other services. If it doesn’t install a unit file for the service, then it’s a bug.
