_OpenMandriva Lx version:_4.0
Desktop environment (KDE, LXQT…): KDE, LXQt
‘skypeforlinux’ is missing in OpenMandriva LX 4.0
How can I install it from any RPM-Package?
with regards
Ch. Hanisch
with regards
Ch. Hanisch
Not missing. It is in non-free repository. So first enable non-free repository and then install it via:
sudo dnf install get-skypeforlinux
Ok.
$ sudo dnf install get-skypeforlinux
Überprüfung läuft : get-skypeforlinux-8.49.0.49-1.x86_64 1/1
Installiert:
Fertig.
with regards
Ch. Hanisch
PS: Why no e-Mail message when a answer-posting is written?
I have installed now get-skypeforlinux. But I can’t work with it.
After start only an Icon in the Tray and than nothing.
What should I do now?
with regards
Ch. Hanisch
I can’t confirm this.
Well, we not build skype, because skype is a proprietary software. We only provide script that downloading in “live” rpm package from Microsoft website and then installing it. So if you have any issue with it - I think this is upstream issue.
But we can look at it.
Run skype from terminal (konsole) and check if anythings is wrong,
BTW. proof that skype work for me on OpenMandriva Cooke with Gnome de.
maybe the library ‘libsecret’ ist missing in Rock-Repositories.
$ sudo rpm -i ~/Downloads/skypeforlinux-64.rpm
Warnung: /home/opa/Downloads/skypeforlinux-64.rpm: Header V4 RSA/SHA1 Signature, Schlüssel-ID df7587c3: NOKEY
Fehler: Fehlgeschlagene Abhängigkeiten:
libsecret wird benötigt von skypeforlinux-8.51.0.92-1.x86_64
But
$ sudo dnf --refresh install get-skypeforlinux
google-earth-pro 20 kB/s | 1.3 kB 00:00
OpenMandriva Rock - x86_64 8.5 kB/s | 1.5 kB 00:00
OpenMandriva Rock - x86_64 - Updates 8.2 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Unsupported - x86_64 8.1 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Unsupported - x86_64 - Updates 9.7 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Restricted - x86_64 8.7 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Restricted - x86_64 - Updates 8.0 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Non-free - x86_64 8.4 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Non-free - x86_64 - Updates 8.6 kB/s | 1.5 kB 00:00
Das Paket get-skypeforlinux-8.49.0.49-1.x86_64 ist bereits installiert.
Abhängigkeiten sind aufgelöst.
Nichts zu tun.
Fertig.
with regards
Ch. Hanisch
I mean, try to run in konsole command to launch skype.
$ skypeforlinux
Nothing anywhere. Only a short indicator in the Tray and after less seconds disappeared.
with regaeds
Ch. Hanisch
No, I have my OpenManriva LX 4.0 in a VirtualBox running.
Perhaps this is the reason?
$ lspci -nnk | grep -EiA3 'vga|3d|display'
00:02.0 VGA compatible controller [0300]: VMware SVGA II Adapter [15ad:0405]
Subsystem: VMware SVGA II Adapter [15ad:0405]
Kernel driver in use: vmwgfx
Kernel modules: vmwgfx
00:03.0 Ethernet controller [0200]: Intel Corporation 82540EM Gigabit Ethernet Controller [8086:100e] (rev 02)
with regards
Ch. Hanisch
No. Tested lx 4.0 rock on VB and Skype also works fine.
I build new version Skype. It is available in Cooker and 4.0. In 4.0 is in non-free/testing repo. So please remove all skype from your os and then enable non-free testing repo and try install it again.
have now in
OM Control Center -> OpenMandriva repo-pcker -> Rock and Release
$ dnf repolist
Letzte Prüfung auf abgelaufene Metadaten: vor 1:13:19 am Sa 31 Aug 2019 13:25:40 CEST.
Paketquellen-ID Paketquellen-Name: Status
cooker-x86_64 OpenMandriva Cooker - x86_64 14.971
google-earth-pro google-earth-pro 2
rock-updates-x86_64 OpenMandriva Rock - x86_64 - Updates 476
rock-updates-x86_64-non-free OpenMandriva Rock - Non-free - x86_64 - Updates 12
rock-updates-x86_64-restricted OpenMandriva Rock - Restricted - x86_64 - Updates 0
rock-updates-x86_64-unsupported OpenMandriva Rock - Unsupported - x86_64 - Updates 57
rock-x86_64 OpenMandriva Rock - x86_64 15.662
rock-x86_64-non-free OpenMandriva Rock - Non-free - x86_64 155
rock-x86_64-restricted OpenMandriva Rock - Restricted - x86_64 164
rock-x86_64-unsupported OpenMandriva Rock - Unsupported - x86_64 13.281
‘skypeforlinux’ works now well.
But after
$ sudo dnf --refresh upgrade
with over thousand updated packages I can’t start the LXQt-Desktop.
with regards
Ch. Hanisch
How can I enable non-free testing repo temporary to install ‘get-skypeforlinux’?
with regards
Ch. Hanisch
I think this would do it:
$ sudo dnf install package_name --enablerepo=rock-testing-x86_64-non-free
Post-edit: But your system is probably ruined because you have a Cooker repo enabled along with 8 repos from Rock release.
Hint for all users: You can easily find answers to questions like this with an internet search.
So, that is the situation.
I have now
$ dnf repolist
OpenMandriva Rock - x86_64 6.7 kB/s | 1.5 kB 00:00
OpenMandriva Rock - x86_64 - Updates 8.4 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Unsupported - x86_64 - Updates 8.3 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Restricted - x86_64 8.8 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Restricted - x86_64 - Updates 7.8 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Non-free - x86_64 9.4 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Non-free - x86_64 - Updates 7.9 kB/s | 1.5 kB 00:00
How can I repair my ruined system without a new installation?
Perhaps is the activation of Cooker instead of Rock in repo-picker a solution?
The management of Update Channels: Cooker (Unstable), Rolling, Rock (Stable), Release (Stable) is very complicated.
with regards
Ch. Hanisch
So you are saying that pick one and use only that one is complicated? No it isn’t. What could be more simple. Use only one.
That sounds like a very bad idea. Cooker is for developers to do work. Not for users at all.
We recommend a fresh install because that is the fastest and easiest way to fix this type of issue.
