Skype not working (Solved)
skype not working on openmandriva 4.1
Please read How to get better results when posting about problems
[grumpy@nvme ~]$ inxi -F
System:
  Host: nvme Kernel: 5.5.0-desktop-1omv4001 x86_64 bits: 64
  Desktop: KDE Plasma 5.17.5
  Distro: OpenMandrivaLinux 4.1 Mercury
Machine:
  Type: Desktop Mobo: ASRock model: X570 Taichi
  serial: <root required> UEFI: American Megatrends v: P2.00
  date: 08/21/2019
CPU:
  Topology: 8-Core model: AMD Ryzen 7 2700X bits: 64
  type: MT MCP L2 cache: 4096 KiB
  Speed: 2797 MHz min/max: 2200/3700 MHz Core speeds (MHz):
  1: 2836 2: 4128 3: 4068 4: 4080 5: 4084 6: 4067 7: 4050
  8: 4048 9: 4126 10: 4109 11: 4061 12: 4065 13: 4138 14: 4050
  15: 3901 16: 4068
Graphics:
  Device-1: AMD Ellesmere [Radeon RX
  470/480/570/570X/580/580X/590]
  driver: amdgpu v: kernel
  Display: x11 server: OpenMandriva X.org 1.20.7 driver: amdgpu
  FAILED: ati unloaded: fbdev,modesetting,vesa
  resolution: 2560x1080~60Hz
  OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.36.0
  5.5.0-desktop-1omv4001 LLVM 9.0.1)
  v: 4.5 Mesa 19.3.3
Audio:
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 /
  570/580/590]
  driver: snd_hda_intel
  Device-2: AMD Family 17h HD Audio driver: snd_hda_intel
  Device-3: Logitech Logitech BRIO type: USB
  driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
  Sound Server: ALSA v: k5.5.0-desktop-1omv4001
Network:
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
Drives:
  Local Storage: total: 1.58 TiB used: 9.14 GiB (0.6%)
  ID-1: /dev/nvme0n1 vendor: Gigabyte model: GP-ASACNE2512GTTDR
  ID-2: /dev/sda vendor: Intel model: SSDSC2BW240A4
  ID-3: /dev/sdb vendor: Intel model: SSDSC2BW240A4
  ID-4: /dev/sdc vendor: Samsung model: SSD 840 EVO 250GB
  ID-5: /dev/sdd vendor: Samsung model: SSD 850 EVO 250GB
  ID-6: /dev/sde vendor: Kingston model: SA400S37240G
Partition:
  ID-1: / size: 47.81 GiB used: 7.53 GiB (15.8%) fs: ext4
  dev: /dev/nvme0n1p3
  ID-2: /home size: 185.17 GiB used: 1.61 GiB (0.9%) fs: ext4
  dev: /dev/nvme0n1p4
Sensors:
  System Temperatures: cpu: 51.2 C mobo: N/A gpu: amdgpu
  temp: 41 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 936
Info:
  Processes: 303 Uptime: 27m Memory: 62.75 GiB
  used: 1.32 GiB (2.1%) Shell: bash inxi: 3.0.37
I downloaded from discover but it doesnt work ie cant call to check audio,video etc
and when I try to install from downloaded rpn I get this error
[’\n Problem: conflicting requests\n - nothing provides libsecret needed by skypeforlinux-8.56.0.103-1.x86_64’]
is openmandriva 4.1 an unfinished project there is a lot of linux software that wont install
guvcview which I use is not available
skype wont install from rpm on the command line due to missing files
Iguess I will find more if I keep looking
Cit:
We are a community driven distribution. We do not have any company that stands behind our back. We allocate only our free time and knowledge to make things run.
If you feel that something is not working, please file a bug report with details which may help us to resolve you issues.
You can post here in the forum as well, but has to be a proper report that is to provide as much informations you can gather: console outputs, screenshots, system infos, and so on.
“My program does not work” or “Skype not working on openmandriva 4.1”
is not acceptable as a support request.
Please describe details of the failure.
mmmmmmmm guess I will have to find something else to fill the vacant drive I will have bit of a shame openmandriva did look promising
well I have decided will leave openmandriva on nvme and see what transpires I am happy the way it works on nvme
Coming soon. I’m building it now for Cooker. If all goes well, then we push it to testing in Rolling and then to
Stable 4.1.
Not sure about Skype. As soon as I find some free time I will try to test this one.
ok thanks for that I might enable testing if I can to help a little bit if you would like that thanks once again
I have changed settings in repos and gone to rolling let me know if thats ok
regards Ron
Rolling is ok. In this edition you will receive quick updates with fresh packages (just like in any other rolling distro).
guvcview is fixed and updated (thanks to @christopher_tanner for testing) Packages is now in testing repo. On Rolling you can install it from unsupported/testing repository.
So in om-repo-picker (or in terminal) you need enable “unsupported” repository and opt for testing.
Then install guvcview in dnfdragora, discover or via terminal: sudo dnf install guvcview
Skype
I have a question, did you install skype from skype.com? Right? If yes, please install it from system repository.
Enable non-free repo then: sudo dnf install get-skypeforlinux
btw. new skype version 8.56.0.103 is in testing repo too.
thanks AngryPenguin they are both working perfect thanks great job both of you
regards Ron
