after todays updates shutdown hangs it takes ages to shutdown,I know of a workaround go to logout on the menu select logout then when logout comes up go to the left side and select the shutdown button from there it shuts down fast
also my wireless mouse hangs at boot I have to unplug it and plug it back in
I did a reinstall everything is ok now
Hi @rbrick49
Just for the record, was it with Ly 2014.2 ?
this problem is back after a new install of openmandeiva Lx 3.o kde
heres my inxi
inxi -F
System: Host: ron-pc Kernel: 4.6.5-desktop-2omv x86_64 (64 bit)
Desktop: KDE Plasma 5.6.5
Distro: OpenMandrivaLinux 3.0 Einsteinium
Machine: Mobo: ASRock model: Z97 Extreme4
Bios: American Megatrends v: P2.30 date: 10/12/2015
CPU: Quad core Intel Core i7-4770K (-HT-MCP-) cache: 8192 KB
clock speeds: max: 3900 MHz 1: 3900 MHz 2: 3900 MHz
3: 3900 MHz 4: 3900 MHz 5: 3900 MHz 6: 3898 MHz
7: 3821 MHz 8: 3826 MHz
Graphics: Card: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
Display Server: OpenMandriva X.org 118.4 driver: N/A
Resolution: 3440x1440@59.97hz
GLX Renderer: Mesa DRI Intel Haswell Desktop
GLX Version: 3.0 Mesa 12.0.1
Audio: Card-1 C-Media CMI8788 [Oxygen HD Audio]
driver: snd_virtuoso
Card-2 Logitech G930 driver: USB Audio
Card-3 Logitech Webcam Pro 9000 driver: USB Audio
Sound: ALSA v: k4.6.5-desktop-2omv
Network: Card: Intel Ethernet Connection (2) I218-V
driver: e1000e
IF: enp0s25 state: up speed: 1000 Mbps duplex: full
mac: d0:50:99:71:21:bc
Drives: HDD Total Size: 1980.4GB (4.1% used)
ID-1: /dev/sda model: Samsung_SSD_840 size: 250.1GB
ID-2: /dev/sdb model: WDC_WD10EZRX size: 1000.2GB
ID-3: /dev/sdc model: Samsung_SSD_850 size: 250.1GB
ID-4: /dev/sdd model: INTEL_SSDSC2BW24 size: 240.1GB
ID-5: /dev/sde model: INTEL_SSDSC2BW24 size: 240.1GB
ID-1: / size: 196G used: 6.8G (4%) fs: ext4 dev: /dev/sdc2
ID-2: swap-1 size: 36.77GB used: 0.00GB (0%) fs: swap dev: /dev/sdc3
ID-3: swap-2 size: 34.04GB used: 0.00GB (0%) fs: swap dev: /dev/sde3
ID-4: swap-3 size: 5.70GB used: 0.00GB (0%) fs: swap dev: /dev/sdd4
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 45.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 252 Uptime: 7 min Memory: 1088.0/31875.9MB
Client: Shell (bash) inxi: 2.2.27
[grumpy@ron-pc ~]$
it hangs on shutdown[quote=“rbrick49, post:4, topic:523, full:true”]
heres my inxi
inxi -F
driver: e1000e
[grumpy@ron-pc ~]$
[/quote]
last night I tested this operating system until the small hours to see what was causing shutdown hang.it apprears if I install dark breeze thats what causes the shutdown problem has anyone else noticed this.I have been running on breeze all day with no problems
regards Ron
Hi Ron, I’ll test, dark Breeze is a kde theme, right?
yes raphael its a kde theme in system setting
I changed the theme but did not see differences.
What happens if you write from konsole
/bin/systemctl poweroff
Is it quick?
yes when I put the code in terminal it shuts down in a couple of seconds and thats with dark breeze now it is taking a long time tp boot up the splash screen with the popies stats off dull in colour then gets brighter before booting
heres some more info for you
systemd-analyze
Startup finished in 7.206s (firmware) + 6.513s (loader) + 3.963s (kernel) + 982ms (initrd) + 3min 386ms (userspace) = 3min 19.051s
systemd-analyze
systemd-analyze blame
12.535s dev-disk-by\x2duuid-29effc33\x2d6651\x2d4908
6.002s rdisc.service
5.092s nmb.service
1.037s user@1001.service
926ms udisks2.service
346ms firewalld.service
246ms upower.service
204ms tuned.service
79ms ModemManager.service
76ms smb.service
67ms accounts-daemon.service
66ms systemd-logind.service
63ms alsa-restore.service
63ms mdmonitor.service
61ms polkit.service
59ms nscd.service
56ms systemd-journal-flush.service
56ms winbind.service
50ms systemd-udev-trigger.service
48ms systemd-udevd.service
45ms lvm2-monitor.service
lines 1-21
not sure if this will help
I hope @TPG can come and see, he knows well systemd…
ok mate
Hi,
according to your systemd-analyze:
It seems like your disk is taking too much time on mounting. Can you umount it and force run fsck to clean potential errors.
ok TPG did that it says no errors.now sda has manjaro, sdb is media, sdc openmandriva, sdd sparky linux and sde is linux mint these are all seperate hard drives all installed uefi each disk has its own grub bootloader so I have no idea what is going on with this all other os boot ok only openmandriva is slow I have an idea its something to do with the swap partition.
