Hi,
Please give a try for 3.03 iso.
x86_64
https://abf.openmandriva.org/platforms/3.0/products/38/product_build_lists/1325
i586
https://abf.openmandriva.org/platforms/3.0/products/41/product_build_lists/1326
These two are missing kernel 4.12.x
Hi,
x86_64
i586
Anyone else is getting a
{"Error 404":["Resource not found!"]}
when you click on the files to download them?
Also wget complains about 404 Not Found
It’s just me or… ?
The ABF certificate has expired you will have to use an security exception.
Colin
Thanks, already noticed earlier this morning. I accepted security exception.
Postedit: Will try with another system ![]()
Same behaviour here.
Same here.
Great…
Murphy’s law
@jclvanier any magic trick of yours ?
Machine kaput!
$ wget http://file-store.openmandriva.org/api/v1/file_stores/eb9a91dee085d48fb5862e8336bbd70c48ad67ab
--2017-07-30 15:31:44-- http://file-store.openmandriva.org/api/v1/file_stores/eb9a91dee085d48fb5862e8336bbd70c48ad67ab
Resolving file-store.openmandriva.org... 188.165.214.207
Connecting to file-store.openmandriva.org|188.165.214.207|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2017-07-30 15:31:44 ERROR 404: Not Found.
Hi All
HisShadow has fixed the issue. I am rebuilding the iso’s x86_64 is first.
Best,
Colin
Thanks.
Icons issue reported in post #38 above and here is no longer an issue. Not sure what happened but icons are OK again here.
Build 1327 downloadable but the speed is far much slower than usual.
Before: ~ 30 MB/s
Today: < 4 MB/s
Maybe the server is overloaded?
I just voted up on Kahinah systemd, dbus, KFrameworks and Plasma package groups. Looks like we need more voters though…
I have installed ISO 1327 on an old PC without any problems. The problem with kalamares not starting up has gone away. Looks good to me.
Chris
Is this same as booting in to ‘Install’?
Yes.
Latest ISO’s with kernel 4.12.5 announced in Devel(Tasters) forum here.
I have a couple of questions for @TPG. On latest ISO’s I notice that there is no longer a screensaver (xscreensaver). Just wondering if that is intentional? No problem here. I don’t require it though I might install it on a hardware system I planned to keep.
Another thing I notice is that if I select to use Erase Disk in partitioning it no longer creates a linux-swap partition. Again no problem here just wondering if this is intentional? I haven’t seen swap used in years on my computers. I would wonder if people on less robust hardware might still have a need for swap, thinking of people that still have i586 for instance?
Hi,
here is the latest ISO
https://abf.openmandriva.org/platforms/3.0/products/38/product_build_lists/1356
This ISO ships kernel 4.12.6 with zstd support.
ISO is compressed with zstd, which should give better performance on boot from live image.
Please give it a testing.
So far I’ve tried a DVD and USB 3.0 stick in both Legacy and UEFI boot in both hardware and VirtualBox. And every time it boots to a dracut prompt.
