when i try to login from the sddm, each and every session but awesome crashes. if i login from a tty and then launch the wm it works.
Hp pavilion with intel i7-11th gen and internal Xe graphics. this problem occurs randomly, but almost all of the time the plasma wayland crashes when i see the desktop.
changing the greeter isn’t new for me : ) one time tried to move off of gdm but saw that there was no benifit and then just sticked with it. thanks wilson!
file /usr/share/dbus-1/system.d/org.freedesktop.DisplayManager.conf from install of lightdm-1.32.0-3.x86_64 conflicts with file from package plasma6-sddm-0.21.0-2.x86_64
Yes, you should remove plasma6-sddm. Then install lightdm. You can try kde-greeter for lightdm too, but for me it was buggy, not looked as it should. I suggest stay with default lightdm greeter.
And remember - lightdm works only with X11, Wayland session isn’t implemented yet.
After installation do:
sudo systemctl enable lightdm
reboot
awesome uses xcompmgr. The others use their own compositor. This is a 3D graphics issue. Previous advice given for this issue was to install kernel-server and test to see if your sessions work.
Thanks for sticking with this. When you know more, please give some feedback in the testing post for this. If the server kernel works, we can find the issue in the differences.
