Seeking help to repair KDE
Hello ladies and gentlemen,
Currently on OpenMandriva Rocks Lx 6.0 since May, first :partying_face:
DISTRIB_ID="OpenMandriva Lx"
DISTRIB_RELEASE=6.0
DISTRIB_CODENAME=Vanadium
DISTRIB_DESCRIPTION="OpenMandriva Lx 6.0"
I’m using Gnome with Wayland on a daily basis with the nvidia driver 575 included in the non free repository. Graphic card : Quadro K620, SDDM login manager disabled in favor of GDM)
To get some extra packages I activated every repository during the last free weeks (non-free, extra, etc…). No packages were manually compiled.
Non critical, I wanted to use temporarily a X11 package with KDE and I couldn’t login or the login freeze or the screen went black. I searched the wiki or the forum, tested various solutions, I couldn’t repair it properly
After trying to update with dnf, I still couldn’t use properly kde. I guess something went wrong.
sudo dnf in task-plasma6
sudo dnf in task-plasma6-x11
sudo dnf in task-plasma6-wayland
command runs fine but kde unusable or x11 on another tty. (Can’t reproduce the steps, I even don’t know how it popped up but succeed running a session with X11)
Trying to downgrade :
Last metadata expiration check: 17:05:16 ago on Tue 16 Jun 2026 04:23:26 PM JST.
Error:
 Problem: problem with installed package plasma6-sddm-0.21.0-2.x86_64
  - package plasma6-sddm-0.21.0-2.x86_64 from @System conflicts with sddm provided by sddm-0.21.0-8.x86_64 from rock-x86_64
  - package plasma6-sddm-0.21.0-2.x86_64 from rock-x86_64 conflicts with sddm provided by sddm-0.21.0-8.x86_64 from rock-x86_64
  - package task-plasma-5.27.3-3.x86_64 from rock-x86_64 requires sddm, but none of the providers can be installed
  - conflicting requests
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages)
[peter@quadra ~]$ sudo dnf in task-plasma --allowerasing
Last metadata expiration check: 17:10:57 ago on Tue 16 Jun 2026 04:23:26 PM JST.
Dependencies resolved.
 Package                        Arch   Version               Repository    Size
Installing:
 task-plasma                    x86_64 5.27.3-3              rock-x86_64  7.8 k
Installing dependencies:
 akonadi                        x86_64 4:23.08.5-3           rock-x86_64  1.2 M
 akonadi-archivemail-agent      x86_64 3:23.08.5-2           rock-x86_64  238 k
 akonadi-calendar               x86_64 23.08.5-2             rock-x86_64  339 k
 akonadi-calendar-tools         x86_64 3:23.08.5-1           rock-x86_64  416 k
 akonadi-common                 x86_64 4:23.08.5-3           rock-x86_64  9.0 k
 akonadi-contacts               x86_64 3:23.08.5-2           rock-x86_64  249 k
 akonadi-followupreminder-agent x86_64 3:23.08.5-2           rock-x86_64  170 k
 systemd-kcm                    x86_64 1.2.1-11              rock-x86_64  186 k
 systemsettings                 x86_64 5.27.12-1             rock-x86_64  386 k
 task-plasma-minimal            x86_64 5.27.3-3              rock-x86_64  7.2 k
 xdg-desktop-portal-kde         x86_64 1:5.27.12-1           rock-x86_64  289 k
 zeroconf-ioslave               x86_64 23.08.5-2             rock-x86_64   66 k
Installing weak dependencies:
 discover-backend-flatpak       x86_64 5.27.12-1             rock-x86_64  116 k
 discover-backend-fwupd         x86_64 5.27.12-1             rock-x86_64   34 k
 kio-admin                      x86_64 23.08.4-4             rock-x86_64   75 k
 kio-kcm_trash                  x86_64 5.116.0-3             rock-x86_64  7.9 k
 krita-ai-diffusion             noarch 1.31.1-1              rock-x86_64  2.0 M
 kwin5-scripts                  noarch 2024.06.12-1          rock-x86_64  8.4 k
 om-feeling-like                x86_64 0.1.8-1               rock-x86_64  798 k
Removing dependent packages:
 plasma6-sddm                   x86_64 0.21.0-2              @rock-x86_64 4.7 M
 plasma6-sddm-kcm               x86_64 6.3.4-2               @rock-x86_64 547 k
 plasma6-sddm-theme-breeze      x86_64 6.3.4-2               @rock-x86_64 579 k
 task-plasma6                   x86_64 6.0.0-1               @rock-x86_64   0
Transaction Summary
Install  623 Packages
Remove     4 Packages
Total size: 569 M
Is this ok [y/N]:
Running transaction check
Transaction check succeeded.
Running transaction test
..... (lots of conflicts)
file /usr/share/polkit-1/actions/org.kde.powerdevil.backlighthelper.policy from install of powerdevil-5.27.12-1.x86_64 conflicts with file from package plasma6-powerdevil-6.3.4-2.x86_64
  file /usr/share/polkit-1/actions/org.kde.powerdevil.chargethresholdhelper.policy from install of powerdevil-5.27.12-1.x86_64 conflicts with file from package plasma6-powerdevil-6.3.4-2.x86_64
  file /usr/share/polkit-1/actions/org.kde.powerdevil.discretegpuhelper.policy from install of powerdevil-5.27.12-1.x86_64 conflicts with file from package plasma6-powerdevil-6.3.4-2.x86_64
  file /usr/share/icons/hicolor/scalable/apps/flatpak-discover.svg from install of discover-backend-flatpak-5.27.12-1.x86_64 conflicts with file from package plasma6-discover-backend-flatpak-6.3.4-2.x86_64
  file /usr/share/libdiscover/categories/flatpak-backend-categories.xml from install of discover-backend-flatpak-5.27.12-1.x86_64 conflicts with file from package plasma6-discover-backend-flatpak-6.3.4-2.x86_64
  file /usr/share/metainfo/org.kde.discover.flatpak.appdata.xml from install of discover-backend-flatpak-5.27.12-1.x86_64 conflicts with file from package plasma6-discover-backend-flatpak-6.3.4-2.x86_64
etc....
Hardcore :slight_smile:
sudo dnf remove plasma6*
[SKIPPED]  ....
[SKIPPED] lib64Qt6Pdf-6.9.0-3-omv6000.x86_64.rpm: Already downloaded
[SKIPPED] lib64Qt6PdfWidgets-6.9.0-3-omv6000.x86_64.rpm: Already downloaded
(624/637): kf6-plasma-activities-stats-6.3.4-1-  11 kB/s | 7.1 kB     00:00
(625/637): kglobalaccel-runtime-6.3.4-2-omv2590  32 kB/s |  23 kB     00:00
(626/637): kf6-purpose-6.13.0-1-omv2590.x86_64. 211 kB/s | 203 kB     00:00
(627/637): lib64KExiv2Qt6-25.04.0-1-omv2590.x86 272 kB/s | 120 kB     00:00
(628/637): lib64KF6Purpose-6.13.0-1-omv2590.x86 584 kB/s | 320 kB     00:00
(629/637): lib64KGlobalAccelD-6.3.4-2-omv2590.x 217 kB/s |  86 kB     00:00
(630/637): lib64PlasmaActivities-6.3.4-1-omv259 302 kB/s | 111 kB     00:00
(631/637): lib64PlasmaActivitiesStats-6.3.4-1-o 223 kB/s |  78 kB     00:00
(632/637): lib64kaccounts6-25.04.0-1-omv2590.x8 208 kB/s |  58 kB     00:00
(633/637): plasma6-kaccounts-integration-25.04. 322 kB/s | 115 kB     00:00
(634/637): plasma6-kglobalacceld-6.3.4-2-omv259  30 kB/s | 7.8 kB     00:00
(635/637): plasma6-libkexiv2-25.04.0-1-omv2590.  26 kB/s | 6.7 kB     00:00
(636/637): plasma6-plasma-activities-6.3.4-1-om  72 kB/s |  19 kB     00:00
(637/637): plasma6-signon-kwallet-extension-25.  72 kB/s |  19 kB     00:00
You can remove cached packages by executing 'dnf clean packages'.
Error: Transaction test error:
  file /usr/lib64/signon/extensions/libkeyring-kwallet.so conflicts between attempted installs of plasma6-signon-kwallet-extension-25.04.0-1.x86_64 and lib64keyring-kwallet16-23.08.5-1.x86_64
  file /usr/share/applications/kcm_kaccounts.desktop conflicts between attempted installs of kaccounts-integration-23.08.5-4.x86_64 and plasma6-kaccounts-integration-25.04.0-1.x86_64
Don’t know what to do, basically I would like to be able to run sometines an alternative kde5 or kde6 environment. Not business critical, any help appreciated. :grinning_face_with_smiling_eyes:
As far as I know Plasma5 and Plasma6 packages on the same system are incompatible. The system has to be either Plasma5 OR Plasma6. To do this you would need a partition for P5 and a separate partition for P6. Or a hw system with one and a VM with the other or a hw system with Gnome and VM’s for the KDEs.
sddm definitely will have problems when you have duplicate sddm packages as shown above.
Thank you for your feedback @ben79 :blush:
I didn’t know about that. I thought there was a conflict between kde5 and kde6 packages but it looks like related to Nvidia… again :sweat_smile: Wayland froze / super slow, I got x11 working after purging / cleaning my install.
Not related, I received earlier my second-used AMD radeon rx550 low profile I purchased and it works SEAMLESS ! ! ! Gnome - KDE - Fluxbox etc.. X11 - Wayland no problems at the moment.
After researching a bit on reddit / google recommendations, this kind of graphic card fit slim tower models on older motherboard with a pcie 2.0 slot like mine and I can confirm that it runs smoothly with Open Mandriva.
Best experience I’ve ever had. It’s like the windows are ready to popup when I put the finger on my keyboard without pressing it. :partying_face:
Nvidia is nice on Windows, with Linux and especially OpenMandriva, if you can, my advise is to just drop it and switch to an AMD card. Nvidia is fine with Rocks but is gonna be a pain with a rolling distro like ROME. To be honnest, to keep using Nvidia, better use another distro, no offenses. :palms_up_together:
