Post-edit: I completely misread your post and posted something that was just wrong. Yes that looks like the correct log. Thanks for providing logs. And line 7 does include plymouth:debug, so I think should be what @TPG needs. Beyond that @TPG knows far more about this than I.
If you could look in /var/log and see if you have the plymouth-debug.log and rename that to plymouth-debug.log.txt and attach that here I’m sure @TPG would appreciate. That log will be key to getting problem sorted.
Also, if you want to add it to your menu, a quick hacky way to do it would be to right click the plasma menu and open “edit applications”… Then create a new item, point it to the brave executable, and save (You can also add a icon).
Brave working fine in OpenMandriva. I have it from two or three months and working fine. Installed from rpm package and even dnf repository working - so updates too. Today was last dev updates and still working for me.
When you add this dnf repository do you see any error?
or maybe error at installation?
If yes, please post i here.
I used the zip file and created links. I tried to install the rpm. but generated some errors. did not install.
Any one knows how to transfer Chorm / Friefox saved passwords from linux / windows to new os?
