I moved from Arch Linux to OpenMandriva about two weeks ago, in order to give it a try. I had some problems with OpenMandriva for which I found solutions in the forum or the internet, but this one I couldn’t solve for the life of me. I had no luck with IA assistance either, so here I come.
Context
I want to install AWS’ CLI in order to manage an S3 bucket. First, I installed the package aws from OpenMandriva’s repository with dnf install aws, but soon I realized it’s an old version that doesn’t support the S3 command I need, namely:
aws s3 sync <local-directory> s3://<my-endpoint> --delete --storage-class=DEEP_ARCHIVE
So, I went to AWS’ official website and downloaded its command-line installer. The installation succeeded, which resulted in a new directory /usr/local/aws-cli and symlinks created in /usr/local/bin. Running aws --version gives:
aws-cli/2.25.12 Python/3.12.9 Linux/6.12.1-desktop-1omv2490 exe/x86_64.openmandriva
Problem
When I use the above command (aws s3 sync) as a regular non-root user, it works as expected, and shows me an output whose first lines are given below:
warning: Skipping file /mnt/backup/borg/config. File/Directory is not readable.
warning: Skipping file /mnt/backup/borg/data. File/Directory is not readable.
warning: Skipping file /mnt/backup/borg/hints.1800. File/Directory is not readable.
warning: Skipping file /mnt/backup/borg/index.1800. File/Directory is not readable.
warning: Skipping file /mnt/backup/borg/integrity.1800. File/Directory is not readable.
warning: Skipping file /mnt/backup/borg/nonce. File/Directory is not readable.
warning: Skipping file /mnt/backup/borg/README. File/Directory is not readable.
(dryrun) delete: s3://<my-endpoint>/borg/README
(dryrun) delete: s3://<my-endpoint>/borg/config
(dryrun) delete: s3://<my-endpoint>/borg/data/0/10
(dryrun) delete: s3://<my-endpoint>/borg/data/0/100
(dryrun) delete: s3://<my-endpoint>/borg/data/0/101
Note that the output above shows “(dryrun)”, as I ran the command with the option --dryrun.
The problem I’m losing hairs over is that when I run that same command as root, it shows no output. It simply returns, as if the option --quiet was passed (though it isn’t):
[root@omlx ~]# aws s3 sync <local-directory> s3://<my-endpoint> --delete --storage-class=DEEP_ARCHIVE
[root@omlx ~]#
Using the option --dryrun (as root) gives no output either.
If you take notice, the warnings I’m getting from the example output above are because /mnt/backup/borg has root-only permissions. That’s one reason I want to run the command as root. The other reason is that I want to run the command from inside an script that runs other root-level commands.
I don’t know if this problem is caused by OpenMandriva or if it’s a defect in the AWS CLI executable. The fact is that when I was on Arch Linux, I was able to use the command aws s3 sync with both root and non-root users, and both would show me the expected output.
Does anyone have any ideia what to do before I go bald? ![]()
Further details
journalctlgives no messages related to the issue whatsoever.awswas configured both in root and non-root users, so the directories/root/.awsand/home/<user>/.awsare identical./etc/sudoerswas changed so thatsecure_pathincludes/usr/local/bin.- Running
aws s3 syncwithsudohas the same effect as running it from a root session: that is, no output. - Running
aws s3 ls s3://<my-endpoint>works and shows the expected output, both with root and non-root users, and also withsudo. - Running
aws s3 syncwith the option--debugdoes show output, both for root and non-root users, but their outputs are pretty much identical and nothing there indicates a problem. - IA assistance directed me at environment variables. I changed some, such as
PATHand others I got fromprintenvthat I thought could change something, but no effect.
System information
- OS: OpenMandriva Lx ROME 25.04
- DE: KDE Plasma 6.3.4 / KDE Frameworks 6.12.0 / Qt 6.9.0
- Linux kernel: 6.12.1-desktop-1omv2490 (64-bit)
