ROME Upgrade: Error with kaccounts-integration
  • OpenMandriva Lx version:
    ROME
    KDE
    When trying to upgrade
sudo dnf --allowerasing distro-sync | tee dsync-log.txt
I’m getting the following terminal output which I copied to https://hastebin.com/share/isokuronic.csharp
    I’m using the znver1 distribution.
Normally I would try to remove the conflicting kaccounts-integration package and try to upgrade again, but I wanted to inform you. Maybe it helps with development.
@eugen-b please do
sudo dnf remove falkon-kde
as suggested here
and try again
sudo dnf --allowerasing distro-sync | tee dsync-log2.txt
I suggest to not clean dnf cache (the dnf clean all command) this time otherwise it will make everything downloaded again (no need)
Thank you for the properly done report.
@eugen-b Thanks for the report, reports like this do help developers and are appreciated.
This is a known error, developers are working on a fix. Just talked to a dev that is working on this right now.
Edit:
Yes indeed. Very helpful.
