ROME & Rock/6.0 in Virtualbox kernel version 6.14.0-2 does not boot
  • OpenMandriva Lx version:
Cooker, ROME, Rock/6.0 in VirtualBox
ALL
New kernel version 6.14.0-2 does not boot in VirtualBox
If it does not boot for you boot in to the previous kernel version. You can remove the not working kernel also.
This has something to do with VBox graphics, but I am not sure exactly what. Possibly this is an upstream problem with VBox.
The most recent working kernel (v. 6.13.8-1) in VBox is available here if you want to install it.
The reports here are based on OM package virtualbox-7.1.4-3 in Cooker host machine. Maybe people running VBox in other distros or Windows will see different results? That would be most helpful to know.
If some of you experience problem with this kernel in hardware then we may really have a bug.
I also noticed this same issue in QEMU/Virt Manager. I had the 6.12.9 iso downloaded from when I first installed OM, and that booted fine after install. I upgraded the VM and now it won’t boot.
Temporary Workaround
https://abf.openmandriva.org/openmandriva/kernel/build_lists
Set graphic controller to VMSVGA
Postedit:
Also cooker machine fully upgraded
This works on with QEMU/Virt Manager too. Just set the “Video” to VGA :+1:
Thanks @rugyada for that tip. Obviously I had not tried changing VBox settings, which is a good idea, maybe the first thing you should do, if you encounter difficulties.
There is a newer kernel 6.14.0-3 version in Cooker that seems to work with VBoxSVGA or VMSVGA set. ROME users can install that if they so desire. Heck Rock users can install that also.
5 posts were merged into an existing topic: OM doesn’t boot after latest update
