ROME major upgrade november 2025
A massive update for ROME is upcoming.
ROME major upgrade expected - #56 by bero
As always, we recommend to disable all third-party repositories before updating.
Then start it from the console with this command so that you have a log for future documentation:
sudo dnf clean all ; sudo dnf distro-sync --refresh --allowerasing 2>&1 | tee dsync-log.txt
Carefully observe what the console returns;
if you have any doubts, abort the transaction and attach the log, otherwise proceed with the update.
