ROME call for testing networkmanager
networkmanager-1.56.0-1 is published to rolling/main/testing. The version in rolling/main/release is 1.54.3-1 so ROME users please test this if you are at all inclined to help with testing.
You obviously have to enable the main/testing repo. If there is a problem reverting is as simple as disabling the testing repo and I think running dnf downgrade networkmanager. (Memory there)
Now I gotta go test this myself.
Hello @ben79, following your directions I installed networkmanager-1.56.0-1.
Two more packages have been updated (for some reason I’m not able attach files)
 OpenMandriva Rolling - Non-free - x86_ 100% |   1.9 KiB/s |   4.1 KiB |  00m02s
 OpenMandriva Rolling - Non-free - x86_ 100% |  15.3 KiB/s |  33.5 KiB |  00m02s
 OpenMandriva Rolling - Restricted - x8 100% |   1.4 KiB/s |   3.2 KiB |  00m02s
 OpenMandriva Rolling - Restricted - x8 100% |  22.5 KiB/s |  38.8 KiB |  00m02s
 OpenMandriva Rolling - Extra - x86_64  100% |   1.8 KiB/s |   3.2 KiB |  00m02s
 OpenMandriva Rolling - x86_64 - Testin 100% |  38.9 KiB/s |  86.8 KiB |  00m02s
 OpenMandriva Rolling - Extra - x86_64  100% | 553.3 KiB/s |   1.5 MiB |  00m03s
 OpenMandriva Rolling - x86_64          100% |   1.7 MiB/s |   5.6 MiB |  00m03s
Repository caricati.
Problema: il pacchetto installato lib64heif-1.21.2-100.x86_64 richiede libSvtAv1Enc.so.2()(64bit), ma nessuno dei fornitori può essere installato
  - impossibile installare sia lib64svt-av1_0-4.0.1-1.x86_64 da rolling-testing-x86_64 che lib64svt-av1_0-2.3.0-1.x86_64 da @System
  - impossibile installare sia lib64svt-av1_0-2.3.0-1.x86_64 da rolling-x86_64 che lib64svt-av1_0-4.0.1-1.x86_64 da rolling-testing-x86_64
  - impossibile installare il miglior candidato all'aggiornamento per il pacchetto lib64svt-av1_0-2.3.0-1.x86_64
  - impossibile installare il miglior candidato all'aggiornamento per il pacchetto lib64heif-1.21.2-100.x86_64
Pacchetto                                 Arch   Versione   Repository             Dimensione
Aggiornamento:
 lib64networkmanager-gir1.0               x86_64 0:1.56.0-1 rolling-testing-x86_64  350.1 KiB
   sostituisce lib64networkmanager-gir1.0 x86_64 0:1.54.3-1 rolling-x86_64          348.9 KiB
 lib64nm0                                 x86_64 0:1.56.0-1 rolling-testing-x86_64    1.6 MiB
   sostituisce lib64nm0                   x86_64 0:1.54.3-1 rolling-x86_64            1.6 MiB
Ignorati pacchetti con conflitti:
 lib64svt-av1_0                           x86_64 4.0.1-1    rolling-testing-x86_64    5.2 MiB
Riepilogo transazione:
 Aggiornamento:      2 pacchetti
 Sostituzione:       2 pacchetti
 Ignorati:           1 pacchetto
Dimensione totale dei pacchetti in ingresso è 593 KiB. Necessario scaricare 593 KiB.
Dopo questa operazione, verranno utilizzati 6 KiB aggiuntivi (installa 2 MiB, rimuovi 2 MiB).
Is this ok [y/N]: [1/2] lib64networkmanager-gir1.0-0:1.56 100% |  78.1 KiB/s |  93.9 KiB |  00m01s
[2/2] lib64nm0-0:1.56.0-1.x86_64        100% | 305.0 KiB/s | 499.3 KiB |  00m02s
[2/2] Totale                            100% | 362.2 KiB/s | 593.2 KiB |  00m02s
Transazione in corso
[1/6] Verificare i file del pacchetto   100% | 133.0   B/s |   2.0   B |  00m00s
[2/6] Preparare la transazione          100% |  29.0   B/s |   4.0   B |  00m00s
[3/6] Aggiornamento di lib64nm0-0:1.56. 100% |   1.1 KiB/s | 100.0   B |  00m00s
[4/6] Aggiornamento di lib64networkmana 100% |   3.3 KiB/s | 100.0   B |  00m00s
[5/6] Rimozione di lib64networkmanager- 100% | 500.0   B/s |   1.0   B |  00m00s
[6/6] Rimozione di lib64nm0-0:1.54.3-1. 100% |   1.0   B/s |   2.0   B |  00m01s
Completato!
So far everything is working well. Thank you.
Depending on the file extension, however plain .txt files are for sure allowed.
Sto sperimentando continui malfunzionamenti con il forum. Sarà solo un mio problema?
Please make sure you are posting logs in English. The sticky in the Support topic about how to ask for support will explain how you do that.
Were you wanting to post a screenshot instead of the text? Please don’t do that, either. People who change the font size of the browser for readability will not be able to change the font size on a screenshot.
networkmanager-1.56.0-1 is published to rolling/main/release repo now.
