Request .ISO for OpenMandriva Lx (ROME) Using KDE SLIM Wayland
Is there any possibility of getting a version of OpenMandriva Lx that is a SLIM version of KDE Plasma using Wayland? If it exists, I am not seeing a download for it anywhere. Basically, I am looking for OpenMandriva with kde-plasma and kde-baseapps.
I have been 'dnf remove’ing KDE bloat then 'dnf install’ing the required components back to use KDE.
sudo dnf remove akregator helium kaddressbook kcalc kdenlive kget kmail kolourpaint kontact korganizer ktorrent kwrite libreoffice* mpv neochat okular qmplay2 skanlite
sudo dnf install lib64KF5Archive5 lib64KF5Auth5 lib64KF5Bookmarks5 lib64KF5Codecs5 lib64KF5Completion5 lib64KF5Config5 lib64KF5ConfigWidgets5 lib64KF5CoreAddons5 lib64KF5Crash5 lib64KF5DBusAddons5 lib64KF5DocTools5 lib64KF5GlobalAccel5 lib64KF5GuiAddons5 lib64KF5I18n5 lib64KF5IconThemes5 lib64KF5ItemViews5 lib64KF5JobWidgets5 lib64KF5KIO5 lib64KF5Notifications5 lib64KF5Service5 lib64KF5Solid5 lib64KF5SonnetCore5 lib64KF5SonnetUi5 lib64KF5TextWidgets5 lib64KF5Wallet5 lib64KF5WaylandClient5 lib64KF5WidgetsAddons5 lib64KF5WindowSystem5 lib64KF5XmlGui5 lib64Magick++7.Q16HDRI_5 lib64Qt5QuickControls2 lib64Qt5QuickTemplates2 lib64Qt6StateMachine lib64audiofile1 lib64dbusmenu-qt5 lib64ddcutil lib64digikamcore lib64digikamdatabase lib64digikamgui lib64fam0 lib64flac++ lib64gps lib64ibus1.0_5 lib64id3_3.8_3 lib64lensfun0 lib64mad0 lib64opencv_imgcodecs lib64opencv_ml lib64pcre2-posix3 lib64polkit-qt5-core-1_1 lib64polkit-qt6-agent-1_1 lib64qt5core5 lib64qt5dbus5 lib64qt5eglfsdeviceintegration5 lib64qt5gui5 lib64qt5gui5-eglfs lib64qt5network5 lib64qt5printsupport5 lib64qt5qml5 lib64qt5qmlmodels5 lib64qt5qmlworkerscript5 lib64qt5quick5 lib64qt5svg5 lib64qt5waylandclient5 lib64qt5waylandcompositor5 lib64qt5widgets5 lib64qt5x11extras5 lib64qt5xcbqpa5 lib64qt5xml5 lib64qtspeech5 lib64scim lib64scim-x11utils lib64xcb-xinerama0 lib64xcb-xv0 libkdcraw libproxy-kde libproxy-networkmanager mariadb-client mariadb-common mariadb-common-binaries milou openmandriva-kde-translation plasma-desktop plasma-integration plasma-integration-qt5 plasma-pa plasma-welcome polkit-kde-agent-1 power-profiles-daemon powerdevil pulseaudio-module-gsettings qt-avif-image-plugin qt-jpegxl-image-plugin qt5-qtwayland scim-common sonnet ssr task-plasma-minimal task-plasma-wayland xsettingsd kf6-kded kmenuedit kscreen kscreenlocker kwrited lib64Qt6SvgWidgets lib64cfitsio lib64kColorPicker lib64kImageAnnotator kf6-threadweaver ksanecore lib64KF6ThreadWeaver lib64KSaneCore6 lib64KSaneWidgets6 lib64Okular6Core lib64spectre1 libksane
kbuildsycoca6
Also, THANK YOU! I am enjoying OpenMandriva and have converted all of my GNU/Linux computers over to it. It is NICE there is at least ONE distro that is not into DEI and Leftist woke crap.
Welcome! We are glad to see you here.
Do you need x86 or zenver?
What I see are this page. The X11 and Wayland are both on here as far as I know.
As far as I can see, those are just X11 versions in the slim editions, at least for the Plasma6 version.
I think his best bet is to install this one (assuming x86) :
and then install Wayland:
Thanks for the replies. I was going to avoid the X11 version of the .ISO. I can download the X11 slim and install Wayland. But I am hoping a pure slime Wayland version will be available soon.
