It seems very interesting. There are always not enough free open source programs like this for Linux.
Who knows if one day or another we may have it packaged for OMLx
Till now G’MIC was available as plugin for GIMP and I use it sometimes.
I believe, GIMP with it’s plugins can do whatever we need, thus making photoshop almost useless
@mandian GIMP is mainly an image retouching software, with brushes, buffers, layers etc.
G’MIC has not features like this; it is originally a command line a processor (greykstoration/cimg), that calculates the whole image in input and reproduces something in output, in one or several passes. The complexity of its calculations are way beyond what the filters and transformations tools of GIMP are capable of, whether filtering, transforming, extruding in 3D from image datasets etc.
@rugyada well G’MIC being rewritten in Qt, and there is also a Krita plugin, maybe it’ll raise some interest
G’mic 2.2.0 is out and like usual there are a lot of improvements. What I wanted to highlight is now the fact it’s fully rewritten in Qt let the code being easily shared between Gimp and Krita (and any other project who may be interested)
There is much more informations (and funny/interesting story-telling) here but in French only, so I translate the Krita part:
Porting the G’MIC-Qt plugin to Krita
When version 2.0 was released, we were pleased to announce a complete rewrite (in Qt) of the G’MIC plugin code for GIMP, so that we had a G’MIC-Qt plugin theoretically “universal”, i. e. which can be adapted to work with any host software other than GIMP. Well, an additional step has been taken, since this plugin was actually extended to integrate with the free digital painting software Krita.
This was made possible thanks to the development work of Boudewijn Rempt (primary maintainer of Krita) and Sébastien Fourey (developer of the plugin). The G’MIC-Qt plugin is now available for the 3.3+ versions of Krita and, even though it does not yet implement all the input-output features of its GIMP equivalent, the feedbacks we have had are quite positive.
This new porting replaces the old G’MIC plugin for Krita, which had not been maintained for some time. The good news for Krita’s users and developers is that they now have a plugin which code is common to the one running on GIMP, and which we will be able to maintain and update (for the most part).
It should be noted that this porting mainly required the writing of a host_krita.cpp source file (in C++) allowing communication between the host software and the plugin, and it is reasonable to think that a similar effort would allow other software to have their own version of the G’MIC plugin, and some 500 image processing filters delivered with it! Heads-up to developers…
I know this is not a solution but if anyone need use krita 4 and gmic2.2 can use appimage build. Just download both app in appimage format, then make it executable and run. Should work fine.
Yep, appimage is working fine since krita 3.2 (? or such) when I first noticed gmic plugin was not working anymore with standard app.
Confirmed, so anyone needing or wanting it can do.
