Realtek card support
  • OpenMandriva Lx version: ROME 24.12 Live USB
  • Desktop environment (KDE, LXQT…): KDE (wayland)
  • Description of the issue (screenshots if relevant): No wired internet connection.
  • Relevant informations (hardware involved, software version, logs or output…): Missing support for Realtek RTL8111/8168/8211/8411 network card. lspci -v output: 72:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 15)
    Subsystem: CLEVO/KAPOK Computer Device 65d1
    Flags: bus master, fast devsel, latency 0, IRQ 17
    I/O ports at 3000 [size=256]
    Memory at 84304000 (64-bit, non-prefetchable) [size=4K]
    Memory at 84300000 (64-bit, non-prefetchable) [size=16K]
    Capabilities:
    Kernel driver in use: r8169
    Kernel modules: r8169
ip link show output:
2: enp114s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
link/ether 80:fa:5b:69:dd:af brd ff:ff:ff:ff:ff:ff
Previously I tried to install r8168-dkms driver and blacklist the r8169 driver, as many thought the latter was not working properly. It didn’t work on any distributions since 6.12 kernel update. Last time I had wired internet connection was with fedora 41 a few weeks ago (cannot remember kernel version).
Can this issue be solved in OpenMandriva? If yes, how and when? Thanks in advance for your replies.
The issue is more is the device supported by kernel.org. You can check that here. If it is and is not working then file a bug report here. Select New issue>Bug report.
If it is not supported by kernel.org is there a Linux driver for the device somewhere else? And if there is would the license be compatible with OM policy. Some licenses we can not support. It there is such a driver somewhere you can make a package request here. Select New issue>Package request.
Edit: You might get a different or quicker answer at OM-Chat. See post below for the wiki link.
Welcome @petrujenac to OpenMandriva and our forum. This forum is for users of OpenMandriva Linux operating systems.
