# journalctl -r -u NetworkManager.service
Oct 17 22:51:50 localhost.localdomain NetworkManager[3946]: <info> [1508298710.9302] device (lo): link connected
Oct 17 22:51:50 localhost.localdomain NetworkManager[3946]: <warn> [1508298710.9188] (/libnm-device-plugin-team.so): failed to load plugin: /usr/lib64/NetworkManager/libnm-device-plugin-team.so: undefined symbol: nm_device_get_configured_mtu_for_wired
Oct 17 22:51:50 localhost.localdomain NetworkManager[3946]: <warn> [1508298710.8225] (/libnm-device-plugin-wwan.so): failed to load plugin: /usr/lib64/NetworkManager/libnm-wwan.so: undefined symbol: _nm_logging_enabled_state
Oct 17 22:51:50 localhost.localdomain NetworkManager[3946]: <warn> [1508298710.8056] (/libnm-device-plugin-adsl.so): failed to load plugin: /usr/lib64/NetworkManager/libnm-device-plugin-adsl.so: undefined symbol: _nm_logging_enabled_state
Oct 17 22:51:50 localhost.localdomain NetworkManager[3946]: <warn> [1508298710.7812] (/libnm-device-plugin-bluetooth.so): failed to load plugin: /usr/lib64/NetworkManager/libnm-wwan.so: undefined symbol: _nm_logging_enabled_state
Oct 17 22:51:50 localhost.localdomain NetworkManager[3946]: <warn> [1508298710.7031] (/libnm-device-plugin-wifi.so): failed to load plugin: /usr/lib64/NetworkManager/libnm-device-plugin-wifi.so: undefined symbol: _nm_logging_enabled_state
PostEdit: Here are 2 more plugins that journalctl shows not loading:
Oct 18 11:13:59 ben79-pc NetworkManager[4255]: <warn> [1508343239.6692] settings: could not load plugin 'ibft' from file '/usr/lib64/NetworkManager/libnm-settings-plugin-ibft.so': /usr/lib64/NetworkManager/libnm-settings-plugin-ibft.so: undefined symbol: _nm_logging_en>
Oct 18 11:13:59 ben79-pc NetworkManager[4255]: <warn> [1508343239.6678] settings: could not load plugin 'ifcfg-rh' from file '/usr/lib64/NetworkManager/libnm-settings-plugin-ifcfg-rh.so': /usr/lib64/NetworkManager/libnm-settings-plugin-ifcfg-rh.so: undefined symbol: _n>
So I had to downgrade some packages indicating that there is a bug in networkmanager 1.8.4-1 packages in testing repo. So I need to do a bug report when I get time… Any way problem is resolved.
Note: The networkmanager 1.6.2-1 packages in main-updates repo are working OK.
The files exist where they are supposed to or so it seems so it must be a linking issue. Any way the problem is these 5 plugins not loading with the new networkmanager/nm packages in main-testing.
