247
September 20, 2025, 1:27pm
21
i created a bug report, so it’s easy to remember, thank you for the reminder
opened 01:27PM - 20 Sep 25 UTC
closed 10:03PM - 28 Sep 25 UTC
solved-cooker
upstream
**OpenMandriva version**:
6.0 rock (but applies to all versions)
**Describe the… bug**:
package Qt 6 Linguist does not have a desktop file for the icon (neither in gnome or kde)
**Steps to reproduce**:
install Qt 6 Linguist from openmandriva repos
**Observed behavior**:
No desktop file for the icon is created, so app is impossibile to launch, app is correctly working if the executable is invoked from its own folder with the terminal, but still this is not ideal
**Expected behavior**:
to have a desktop file which creates an icon on the app grid for launching the program
247:
Can you edit your bug report to specify it’s an issue of not having the .desktop file? Since it’s not exactly an icon issue. Just to make it a little more clear for whoever is maintaining the Qt Linguist package
system
(system)
Closed
October 20, 2025, 1:41pm
23
