Operating System: OpenMandriva ROME 25.01
KDE Plasma Version: 6.2.5
KDE Frameworks Version: 6.10.0
Qt Version: 6.8.1
Kernel Version: 6.12.9-desktop-1omv2490 (64-bit)
Graphics Platform: X11
Processors: 12 × Intel® Core™ i7-8700 CPU @ 3.20GHz
Memory: 31.3 GiB of RAM
Graphics Processor: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2
I want to install a7800 which is an emulator for the atari 7800. I already failed trying to do a bottles version so time to do it the right way. I figured I better ask If the syntax is al good before I go dicking around with my system and probably screw it up.
The directions state to
A 64-bit binary has been provided, which should be compatible with recent versions of the OS. You will need SDL2 runtime libraries installed. If the provided binary doesn’t work on your platform, you can try building your own from source code.
To install A7800, download one of the packages, and from a terminal execute the commands that follow.
Unpack the zip file…
# tar -xvzf a7800-linux-v5.2.tgz
Ensure that the /usr/local/bin common binary directory exists. This can be skipped if it does exist, or performed without harm if you’re not sure…
# sudo mkdir /usr/local/bin
Copy the executable to /usr/local/bin, ensuring all can execute it…
# sudo cp a7800-linux/a7800 /usr/local/bin/a7800 # sudo chmod 755 /usr/local/bin/a7800
If you haven’t run A7800 or MAME before, create a directory for the configuration, and generate a default configuration…
# mkdir ~/.a7800 # a7800 -cc # mv a7800.ini ~/.a7800
(Optional) Create a directory to hold your a7800.zip (NTSC) or a7800p.zip (PAL) BIOS ROMs…
# sudo mkdir -p /usr/local/a7800/roms
Create a directory to hold your A78 game ROMs…
# sudo mkdir -p /usr/local/a7800/software/a7800
Edit your configuration file to tell A7800 where you’ve put BIOS ROMS. You may also wish to change “mouse 0” to “mouse 1” under “CORE INPUT OPTIONS”, to enable using the mouse with paddle, trackball, driving controller, and mouse emulation…
# nano ~/.a7800/a7800.ini
Be sure to put your A7800 BIOS zip file(s) in your ROMS directory, A78 game files in your SOFTWARE directory, and don’t forget to make sure your ROMS directory is listed in your a7800.ini file.
Did this all sound about right?
