I’m new to Omlx and I’m trying to install ruby trough RBENV everything is fine, until I actually try to install a Ruby and I get “no acceptable C compiler found in $PATH” - any sugestions would be greatly aprecited!
Thnx
For the purposes of this book, you’ll need to have Ruby and RubyGems installed on your machine. We recommend that you use Ruby version 3.0.x, 3.1.x, or 3.2.x. We recommend Ruby 3.2.0 as the best choice. You may experience some issues with other versions, so install 3.2.0 if you can…
…Some system Ruby installations, especially on Mac, have limited permissions and will impede your ability to install gems, upgrade Ruby, and perform other development tasks. Therefore, even if your system comes with Ruby, you should install a separate version of Ruby.
If you’re technically inclined, you can try… rbenv… [which] allow[s] you to run different versions of Ruby side by side, and allow you to switch between them freely.
I can’t seem to install any Ruby versions and I can’t seem to figure out why. rbenv itself installed cleanly on OMLx ROCK 6 Vandium.
