Problems with some games on steam
have steam and the installed games (i suppose)
OpenMandriva 6.0 Rock Gnome
Gnome
so, seems like i am facing some problems in some games (they are starting to be quite a few now) on steam
for example i tried playing Deponia Doomsday (which is a native game) but it has no audio at all
the first Runaway does start (with newest protons) but has no video and no sound at all
Broken Sword 2, has no sound at all in the original scummvm version
Amd Ryzen 7 - Amd Radeon 6600 - 16 gb ram
i supposed maybe some codecs were missing, cause the same games have no problems at all on another distro, so i tried installing all of them, but that didn’t solve my issue
now, considering it seems not to be a proton issue cause it happens either on native and windows games, and the same games does start on another distro, maybe someone can help me track down the issue?
Unfortunately, you will have to check protondb or Valve’s GH for the Issue specific to those games. We don’t use native mode, which means the libraries for the games are delivered in SLR.
thank you for your answer, can i ask you what’s native mode?also, do you think using the flatpak may solve the issue?
i already checked on protondb but unfortunately nobody is having those problems, in fact games are marked as native/platinum for deponia and broken sword and gold for runaway
can i install the flatpak version of steam alongside the rpm version, to see if it changes something?
Native mode is a testing/unsupported feature that allows people interested in testing game support to use the system libraries instead of the older ubuntu derived libraries. I don’t recommend using it for just playing a game.
No. I believe you would have a problem with shortcuts, and you would also need to recreate your Steam library.
For non-native games, you can check for help here:
For native games, you might have to use their Community forum on Steam, or contact them directly.
so, i’ve been able to try the flatpak version of steam, and to my surprise Broken Sword 2 works flawlessy (which is native)
now i am downloading the other two games, to try, but at this point i kinda have the impression that there is something weird on the native steam rpm then…
i’ll keep the post updated, in case someone hits the same problem…
finally made it to try the other games
(un)fortunately they all works flawlessly with the flatpak version so i do assume there is something wrong in how the steam rpm is build/packaged?
i’m no expert but i can only assume so considering the flatpak and steam in rpm from another distro both works perfectly
Everything in non-free and flatpak are provided for convenience. You would have to work with the upstream on Steam just like you would with nvidia because the Steam client is not open source.
unfortunately, yesterday the controller stopped working with the flatpak version, and there was no way to get it back
so i had to return to the rpm version steam
at this point i suppose i should ask valve and/or the developers of the games…
You should probably start in the Community for each game on Steam. They may have pinned something already.
Can you try running steam from console and then running games.
Console output should show somethings. Maybe missing dependencies. It would help.
thank you for your time,
let me try to start steam from console, to see if i can gather some more informations
this is from when starting pang adventures, the game launches to a black screen, with music playing, and then asks directly if i want to force quit the app
the game is marked as platinum on protondb and it’s one of those “out of the box” with none having problems. Also i already finished it on another distro with no problem
x86_64-linux-gnu-capsule-capture-libs: warning: libudev.so.0 has an unexpected DT_SONAME, ignoring: libudev.so.1
setlocale "it_IT.utf8": No such file or directory
pv-locale-gen: Missing locale it_IT.utf8 (found in $LC_ADDRESS)
pv-locale-gen: Generating locale it_IT.utf8...
pv-locale-gen: Generated locale it_IT.UTF-8 successfully
pv-locale-gen: Generating locale en_US.UTF-8...
pv-locale-gen: Generated locale en_US.UTF-8 successfully
pv-adverb[7367]: W: Container startup will be faster if missing locales are created at OS level
fsync: up and running.
failed evaluation of identifier win32_process_name on hwnd-1007a
System.InvalidOperationException: Cannot process request because the process (288) has exited.
  at System.Diagnostics.Process.GetProcessHandle (System.Int32 access, System.Boolean throwIfExited) [0x0004e] in <1b0778429c3b48b2b04d03b739e1ce24>:0
  at System.Diagnostics.Process.GetProcessHandle (System.Int32 access) [0x00000] in <1b0778429c3b48b2b04d03b739e1ce24>:0
  at System.Diagnostics.Process.get_ProcessName () [0x0000d] in <1b0778429c3b48b2b04d03b739e1ce24>:0
  at (wrapper remoting-invoke-with-check) System.Diagnostics.Process.get_ProcessName()
  at Xalia.Win32.HwndProvider.ChildEvaluateIdentifier (System.String identifier, System.Collections.Generic.HashSet`1[T] depends_on) [0x00073] in <5b50cb9692864a58a57a8b9091dd6c44>:0
  at Xalia.Win32.HwndProvider.EvaluateIdentifier (Xalia.UiDom.UiDomElement element, System.String identifier, System.Collections.Generic.HashSet`1[T] depends_on) [0x005a7] in <5b50cb9692864a58a57a8b9091dd6c44>:0
  at Xalia.UiDom.UiDomElement.EvaluateIdentifierCore (System.String id, Xalia.UiDom.UiDomRoot root, System.Collections.Generic.HashSet`1[T] depends_on) [0x00015] in <5b50cb9692864a58a57a8b9091dd6c44>:0
  at Xalia.UiDom.UiDomValue.EvaluateIdentifier (System.String id, Xalia.UiDom.UiDomRoot root, System.Collections.Generic.HashSet`1[T] depends_on) [0x00000] in <5b50cb9692864a58a57a8b9091dd6c44>:0
chdir "/home/legacychimera247/.local/share/Steam/steamapps/common/Pang Adventures"
ERROR: ld.so: object '/home/legacychimera247/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/legacychimera247/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Game Recording - would start recording game 415150, but recording for this game is disabled
Adding process 7491 for gameID 415150
Adding process 7492 for gameID 415150
Adding process 7493 for gameID 415150
pv-adverb[7575]: W: Container startup will be faster if missing locales are created at OS level
Adding process 7606 for gameID 415150
Adding process 7607 for gameID 415150
Adding process 7608 for gameID 415150
Adding process 7609 for gameID 415150
Adding process 7612 for gameID 415150
Adding process 7614 for gameID 415150
Adding process 7617 for gameID 415150
Adding process 7627 for gameID 415150
Adding process 7632 for gameID 415150
Adding process 7639 for gameID 415150
Adding process 7663 for gameID 415150
Adding process 7682 for gameID 415150
pid 7610 != 7609, skipping destruction (fork without exec?)
Game Recording - game stopped [gameid=415150]
this is deponia doomsday, which does start indeed, but has problems with the intro video and has no sound at all (this is also linux native)
i already tried with another distro and has no problem at all
chdir "/home/legacychimera247/.local/share/Steam/steamapps/common/Deponia Doomsday"
Game Recording - would start recording game 421050, but recording for this game is disabled
Adding process 8267 for gameID 421050
Adding process 8268 for gameID 421050
Adding process 8269 for gameID 421050
pv-adverb[8352]: W: Container startup will be faster if missing locales are created at OS level
Adding process 8383 for gameID 421050
pid 8387 != 8383, skipping destruction (fork without exec?)
pid 8392 != 8383, skipping destruction (fork without exec?)
Adding process 8413 for gameID 421050
Adding process 8414 for gameID 421050
Adding process 8415 for gameID 421050
Adding process 8416 for gameID 421050
Adding process 8417 for gameID 421050
Adding process 8418 for gameID 421050
Adding process 8419 for gameID 421050
Adding process 8420 for gameID 421050
Adding process 8421 for gameID 421050
Adding process 8422 for gameID 421050
Adding process 8423 for gameID 421050
Adding process 8424 for gameID 421050
Adding process 8425 for gameID 421050
Adding process 8426 for gameID 421050
Adding process 8427 for gameID 421050
Adding process 8428 for gameID 421050
Adding process 8429 for gameID 421050
Adding process 8431 for gameID 421050
Adding process 8432 for gameID 421050
Adding process 8433 for gameID 421050
Adding process 8434 for gameID 421050
Adding process 8435 for gameID 421050
Adding process 8436 for gameID 421050
Adding process 8437 for gameID 421050
Adding process 8438 for gameID 421050
AL lib: (EE) AddFileEntry: Invalid header in /usr/share//openal/hrtf/default-44100.mhr: "MinPHR02"
AL lib: (EE) AddFileEntry: Failed to load /usr/share//openal/hrtf/default-44100.mhr
AL lib: (EE) AddFileEntry: Invalid header in /usr/share//openal/hrtf/default-48000.mhr: "MinPHR02"
AL lib: (EE) AddFileEntry: Failed to load /usr/share//openal/hrtf/default-48000.mhr
11:30:11.346:Loading from /home/legacychimera247/.local/share/Steam/steamapps/common/Deponia Doomsday/config.ini
No HRTFs found
HRTF not enabled!
11:30:12.471:Loaded steam library.
Setting breakpad minidump AppID = 421050
Steam_SetMinidumpSteamID:  Caching Steam ID:  76561198043478263 [API loaded no]
11/04 11:30:12 minidumps folder is set to /tmp/dumps
11/04 11:30:12 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20251003022621)/tid(8460)
11/04 11:30:12 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(8460)
Input #0, matroska,webm, from 'videos/video.vv058':
  Metadata:
    encoder         : libebml v1.3.0 + libmatroska v1.4.1
    creation_time   : 2015-04-14 13:27:32
  Duration: 00:00:04.04, start: 0.000000, bitrate: 2510 kb/s
    Stream #0:0: Video: vp8, yuv420p, 1920x1080, SAR 1:1 DAR 16:9, 25 fps, 25 tbr, 1k tbn, 1k tbc (default)
    Stream #0:1: Audio: vorbis, 44100 Hz, stereo, fltp (default)
Input #0, matroska,webm, from 'videos/video.vv056':
  Metadata:
    creation_time   : 2016-02-05 09:30:33
  Duration: 00:00:07.02, start: 0.000000, bitrate: 5278 kb/s
    Stream #0:1: Audio: vorbis, 48000 Hz, stereo, fltp (default)
11:31:18.987:stack traceback:
	[C]: in function 'debugerror'
	[string "function debugfunc(err) debugerror(err) end"]:1: in function <[string "function debugfunc(err) debugerror(err) end"]:1>
	[C]: in function 'drawSprite'
	[string "(30,153)"]:161: in function 'drawBanner'
	[string "drawBanner()"]:1: in main chunk
11:31:18.987:Failed to run string in Lua:
11:31:18.987:String content: drawBanner()
this is runaway - a road adventure, it does launch to a black screen with sound then asks me if i want to force quit it
for the record i’ve finished it without problems on another distro
chdir "/home/legacychimera247/.local/share/Steam/steamapps/common/Runaway A Road Adventure"
Game Recording - would start recording game 7210, but recording for this game is disabled
Adding process 4681 for gameID 7210
Adding process 4682 for gameID 7210
Adding process 4683 for gameID 7210
pv-adverb[4765]: W: Container startup will be faster if missing locales are created at OS level
Adding process 4796 for gameID 7210
Adding process 4797 for gameID 7210
Adding process 4798 for gameID 7210
Adding process 4799 for gameID 7210
Adding process 4802 for gameID 7210
Adding process 4804 for gameID 7210
Adding process 4807 for gameID 7210
Adding process 4817 for gameID 7210
Adding process 4822 for gameID 7210
Adding process 4829 for gameID 7210
Adding process 4853 for gameID 7210
Adding process 4872 for gameID 7210
11/04 12:09:37 minidumps folder is set to /tmp/dumps
11/04 12:09:37 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20251003022621)/tid(4942)
11/04 12:09:37 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(4942)
pid 4800 != 4799, skipping destruction (fork without exec?)
Game Recording - game stopped [gameid=7210]
this is broken sword 2, which is native, it has two games, the remastered edition which plays just fine (it’s a native game) and the original one, which is played throught scummvm. This version has no sound at all, but it works perfectly on another distro
chdir "/home/legacychimera247/.local/share/Steam/steamapps/common/Broken Sword 2"
Game Recording - would start recording game 33600, but recording for this game is disabled
Adding process 6386 for gameID 33600
Adding process 6387 for gameID 33600
Gtk-Message: 12:13:04.695: Failed to load module "pk-gtk-module"
Using configuration file: ./Original/scummvm.ini
Adding process 6389 for gameID 33600
WARNING: SDL mixer output buffer size: 2048 differs from desired: 4096!
WARNING: You are missing a valid 'translations.dat' file. GUI translation will not be available!
WARNING: Could not find theme 'scummmodern' falling back to builtin!
11/04 12:13:04 minidumps folder is set to /tmp/dumps
11/04 12:13:04 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20251003022621)/tid(6414)
11/04 12:13:04 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(6414)
there are some others, but i suppose that’s enough, i don’t want to make this list longer than it already is… :slight_smile:
Looks like Runaway: A Road Adventure mostly has French speaking people:
Broken Sword 2, not the remake…
Looks like you already asked and the issue is with SCUMMVM. I would suggest here:
nicely enough, the deponia development team answered me, and asked me to sent them a specific game folder, so they can check
will keep the post updated…
